I have the opposite problem with ancient Sears openers. They open on their own. I have to kill the circuit with a 2nd remote. I live a mile from a major airport. Don't know. |
Yes, my car has a Homelink system in it. Worked fine last time I parked the car in the garage.
The remote I tried in my wife's car is the same as the one I keep at my desk as a spare. It got a new battery and still won't work. |
I had something similar happen, I needed to clear all programs on the opener then reprogram the opener to the remotes.
The arm push isn't working either.
Hmmm, clearing all programs on the opener as in taking out all the settings for opening/closing functions too?
Not sure...but most of them will plug right in...universal. |
Call a garage door service company.
I just did a little experiment. I opened the door with the wall switch out by the door. Got it up and then pushed the button to stop it. Pushed again and the door started to come down. Stuck my foot under the door to interrupt the beam and the door stopped and started to open like it should.
That tells me that the sensors are 'GOOD'. Am I correct? |
Have you tried reprogramming the homelink in the car to the opener?
BTW, your sensors are good if they work with the wall station. |
I'd say 'yes' your experiment eliminated the sensor problem.
Since you have a static code garage door opener, why not just upgrade to a rolling code remote unit?
Something like this. https://www.homedepot.com/p/Genie-Universal-Garage-Door-Opener-Remote-Upgrade-Kit-Add-Modern-Intellicode-Security-To-Your-Old-Garage-Door-Opener-GIRUD-1T/100654121 Otherwise I would just try to reprogram the existing remotes and see if that fixes it. |
Cycle power to the opener. You have a wireless coms issue. If it still doesn't work use the reprogram/learn button and reteach it. |
Give this a whirl if all else fails. :D
“O most holy apostle, Saint Jude, faithful servant and friend of Jesus, the Church honoureth and invoketh thee universally, as the patron of hopeless cases, and of things almost despaired of. Pray for me, as I am desperate need for my home to be complete, for my children to gain strength and honor and for the money to be there to finish the things the home needs completed. Make use, I implore thee, of that particular privilege accorded to thee, to bring visible and speedy help where help was almost despaired of. Come to mine assistance in this great need, that I may receive the consolation and succor of Heaven in all my necessities, tribulations, and sufferings, particularly (here make your request) and that I may praise God with thee and all the elect throughout eternity. I promise thee, O blessed Jude, to be ever mindful of this great favour, to always honour thee as my special and powerful patron, and to gratefully encourage devotion to thee. Amen.” OR! You can go the other route and just cuss at the thing. I normally go the cussing route. I find it helps me feel better even though it doesn't fix what I'm cussing at. |
I'm going to give clearing the programing and re-learning the remotes a try.
Thanks for the help, I'll let you all know how it goes. I will try cycling the power to the opener first though as that is easier. :>) |
I enable mine each night before bed. |
I haven't used that vacation switch very much, but recently when we leave for an overnight or long day away I will hit it.
Could a blown circuit in the wall switch that has that button on it cause this problem? The light blinks like it's supposed to when it's in the 'pushed' position. |
| All times are GMT -8. The time now is 02:38 AM. |
