Garage door opener not responding...
So I'm getting ready to leave for the dentist this morning and go to close the garage door with my homelink button in the car....and nothing happens.
Push it numerous times and same result...nothing happens. Get out of the car and go into the garage and push the button on the wall...door closes. Push the same button again and it opens perfectly. Try the remote fob in my wife's car and....nothing happens. Push her car out of the garage since she has a dentist apt too and won't be able to close the door from in her car so.... Anyways, I get home from the dentist and the door is still unresponsive. I google the manual and all the lights on the control panel are 'Normal'. I unplug/replug in the Modular Transmitter and try a remote which I've put a new battery into....and....nothing happens. I think I need a new Modular Transmitter. How do you find stuff like that? I've googled it and nothing comes up? It's a Martin DC3700e opener that works fine, as long as you are pushing a hardwired button attached to it. Any help would be greatly appreciated as we use our garage door as a front door most of the time. |
Are your obstruction lights showing the right color? (the ones on the tracks on both sides)
Any chance you just changed the light bulb in the opener? I've not experienced it myself, but I've seen many references to some LED bulbs causing problems with remote operation on door openers.
The light works fine and has been in there a long time. The only thing about the opener that doesn't work is it won't respond to a remote controller.
Page 18
https://www.martindoor.com/wp-content/uploads/2019/02/2002opener_AllPage-2.pdf Look to make sure you did not hit the vacation lock button. I did this with mine it drove me nuts until I figured it out. |
I cleaned the sensors with a q-tip so they are not obstructed.
It is the Democrats taking over control of your life...first the mandate and then the Garage door opener when will these depredations cease...
there is also a RESET BUTTON on those things... You must be an OC Republican who are renowned for their ahhh challenged IQ's. |
Didn't hit the vacation button and the light blinks when it is 'engaged' so that is working OK.
The only challenged IQ is the IQ of some of my camera lenses tabs.
I guess sticking a button outside on the wall is out?
some troubleshooting that I assume you've seen, but just in case. Quote:
I've found several replacement fobs, but not having as much luck finding the central receiver/transmitter.
Yes, putting a button outside is not an option.
The reason I mention this...mine failed on me (one light was yellow) and I couldn't get it to make contact with the other. Needed to replace the set...works fine now. |
I'm going to suggest something very embarrassing.
Don't ask me how I know. On my interior manual buttons is a "lock" feature, which lets you open the door from the inside, but locks out all remote keys. When the genius (me) unlocked the doors, the remotes worked again. |
What happened to the remote? None of our cars have an in car opener. We just carry the remote. You can buy those and program them in less than a minute.
I will go double check the sensors....
Some cars these days come with remotes built into the car that you can program just like you would a separate remote. |
There are no LED's on the sensors.
http://forums.pelicanparts.com/uploa...1634068054.JPG http://forums.pelicanparts.com/uploa...1634068054.JPG http://forums.pelicanparts.com/uploa...1634068054.JPG http://forums.pelicanparts.com/uploa...1634068054.JPG As you can see, they're old as dirt.:D |
If you've gotten the COVID vaccine you can push on your arm where the shot was and the door will open. One push to open, two pushes to close.
| All times are GMT -8. The time now is 12:36 PM. |
