Send a message via AIM to fintstone
[QUOTE=jyl;11488794]... I guess the prior guy threaded it on at the elbow, not sure.
.../QUOTE]
Most likely. That would be typical.
Good work. I was afraid you would hesitate...as it sounds a bit crazy to use a flame if you have not done it before. I do that after any install to check for leaks when I first turn the gas back on (making sure I have cleared any gas from the room first). Of course I am self taught and just telling you how I do it. Might not work for everyone...so I always recommend others hire a pro.
That was a pretty good sized leak. Good thing you took care of it.
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 10-17-2021, 04:41 PM
jyl jyl is online now
jyl's Avatar
Thanks fint,
Everyone here is your nightly bulletin - jyl has not blown up yet
Old 10-17-2021, 07:19 PM
