LinkBack Thread Tools Rating: Thread Rating: 2 votes, 1.00 average.
Team California
speeder's Avatar
Originally Posted by mattdavis11 View Post
Why did it need a new compressor? I always question the competency of anyone doing a/c work. That's my gig.
I can't tell you what the numbers should be, but if it has a computer system that recognizes the ambient temperature, it shouldn't even engage at 40 degrees. Your someone may have to send 12v to the clutch coil to get it to engage.
It needed a new compressor because the clutch was destroyed on the old one, (made a disgusting noise), and an entire new Denso compressor was about the same price as a clutch. The A/C did not work at all previously. I bought it like that.
I wanted to replace the dryer but it's one piece w the condenser on this model, so I did not. Doesn't the A/C go on at any ambient temp w defrost setting?
So I am going to see some numbers tomorrow and hopefully get more info from them. I'll look for the numbers that Scott mentioned above. The van is going to mostly sit all winter and obviously the A/C won't be needed but if I wait until spring and it doesn't blow cold, they will just tell me that it leaked out during the winter. I want it working properly now.
Denis
Old 11-03-2021, 08:47 PM
Just thinking out loud
mattdavis11's Avatar
Rubber dampner went bad. Been there, have the parts.
91 FJ80
84 Ram Charger (now gone)
Old 11-03-2021, 08:53 PM
I check mine with the normal dash vents, fan speed 2, windows up, recirculate.
91 FJ80
Old 11-03-2021, 08:55 PM
Scott R's Avatar
This is my sanity check, this was an XJR this summer.
Old 11-03-2021, 09:02 PM
Scott R's Avatar
But I start with this.
Old 11-03-2021, 09:08 PM
UnRegistered User
billybek's Avatar
Could be that there is a leak now and maybe there was before.
The drier is not replaceable? Cripes, who thought of that nonsense.
Bill K.
Old 11-04-2021, 06:20 AM
Brew Master
cabmandone's Avatar
Thanks, guys. The compressor is engaging for sure but the air coming out of the vents on coldest setting is more or less the same temp whether the compressor is engaged or not. Shouldn't it be blowing ice cubes at this ambient temp?
At the ambient your mentioning? Not really. But it should be colder than ambient. I'd guess at the ambient you're talking your suction side will be 25-35 range without looking at any pt charts.
If it's low on gas, I'd umm... "reclaim the existing refrigerant" and put the unit in a vacuum with a thermistor vac gauge connected so I could see how fast the vaccum was rising and determine how bad the leak is. If the thermistor changes minimally I'd weigh in the proper charge and call it a day.
Nick
Old 11-04-2021, 06:50 AM
Team California
speeder's Avatar
Ok, put the gauges on it:
I brought it by the shop that installed the compressor this morning and got them to put gauges on it. I should have taken a photo but the numbers were ridiculously low, like 100 on the high side and 20 or less(?) on the low side. I was on the way to the airport with a friend in tow who is keeping the van for me, so we agreed to revisit it in the springtime. I just needed them to acknowledge the problem now.
The caps for the Schrader valves were missing and one of them seemed to leak some freon when he disconnected the gauge but it was not leaking prior, the green freon is pretty unmistakable when that happens. My caps are probably sitting on their A/C machine and if the valve is bad, the tech should have noticed it when he filled it. These are the basics. No one ever checked the charge.
I really, really appreciate the knowledge shared by Scott and Matt plus Nick on this thread. A/C is not an area of expertise for me but I'm slowly becoming more fluent in it, thanks to you guys.
Denis
Old 11-04-2021, 07:22 AM
Brew Master
cabmandone's Avatar
That high side is crazy low. I had that happen on an older car and it was a pressure control valve in the compressor that I had to change. No matter what I did the discharge remained low IIRC.
The suction side is a bit low for the ambient but not overly shocking IMO. Valves are a common leak spot. They should have changed the needles when they did the compressor just to take care of a common leak area.
Something else: I don't know if Honda has a sight glass like Toyota puts in their vehicles but if they do that's a great way to tell what kind of charge you have. I'm also wondering if the compressor on your van doesn't have a stuck pressure control valve. I know it's new but from looking, it appears they have this valve in them.
If you run into trouble when you're looking at it in the spring, you've got my number. You're welcome to give me a call if needed.
Nick
Old 11-04-2021, 09:01 AM
The caps on the valves are considered part of the AC system. They really need to be in place. Often the caps even have an o-ring.
With pressures that low, the compressor likely should no be running unless it was had a jumper wire on it to force it to run.
It really works best to charge a AC system in 90 degrees and up temps to get accurate pressures.
Old 11-04-2021, 09:13 AM
Fleabit peanut monkey
Bob Kontak's Avatar
At first blush I say not enough refrigerant but just tuned into the thread.
1981 911SC Targa
Old 11-04-2021, 01:49 PM
I'm looking at Scott's gauges and temp probe and saying over charged. What was the ambient? Must have been 110F.
Denis, that's too low in my opinion, on both sides, it needs more to tell me more. Good thing is, it will suck, but the high side valves may have been hammered when they charged the system.
I don't know how they charged it. I have my way, but it's not the same for an orifice tube car as it is for an expansion valve car. They may have turned the can upside down, or charged as a liquid, and we all know you can't compress liquid.
I would would look at the pressure at equilibrium given ambient temp, and move forward. I can't do that here for you.
Good points mentioned above on the schrader valves, same deal as when you were a kid and had to air up your bike tires in the spring. They can develop leaks, and should be replaced prior to a vacuum. Spit on them, do they bubble? There you go.
91 FJ80
Old 11-04-2021, 04:13 PM
I’m betting this thing has a pretty good leak.
Old 11-04-2021, 04:24 PM
Scott R's Avatar
About 90 that day if I recall. I was in a nice shaded shop though, and I was blowing air through the condenser.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 11-04-2021, 04:25 PM
Did it respond correctly when water was poured on prior, and work well without water after you changed the condenser?
I'm curious. Was in an accident prior, and the body shop put in a 5mm condenser and not a 6? I haven't even looked to see if was a microtube serpentine, or parallel flow, no idea what the car came with.
91 FJ80
Old 11-04-2021, 05:50 PM
Team California
speeder's Avatar
If that is the case, it should have been discovered when they put vacuum to the system.
Denis
Old 11-04-2021, 09:44 PM
A vacuum is just a bit over 14 PSI. Not a major pressure difference. That is why I always pressurizes with dry nitrogen to look for leaks. 50 to psi is not over pressurizing anything and will show you bubbles when soapy water is applied.
Few pros bother with the extra work of using nitrogen.
Old 11-05-2021, 05:58 AM
Well, that would depend entirely on how they did it; they might’ve just pulled a vacuum and loaded the Freon into the system. They may not have actually tested it for a leak.
Old 11-05-2021, 06:43 AM
UnRegistered User
billybek's Avatar
The capless shrader valves may have been the source. I can't imagine how such a simple step was forgotten.
Not a very big charge in most automotive a/c systems. A small amount missing makes a huge difference in performance.
Not a huge fan of leak checking by vaccuum either. If you do have a leak, the oil charge can become contaminated with moisture. PAG oils are hygroscopic as are POE oils.
Bill K.
Old 11-05-2021, 07:33 AM
Scott R's Avatar
Yes, this is the best way by far. At least for me.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 11-05-2021, 11:05 AM
