Senior Member
Riddle
Three travelers stop at a motel and ask for a room. Manager says the room is $30 and they each pull out a $10 bill. Later, the manager comes to them with five $1 bills, and reporting he erred by charging them the weekday rate on a weekend when rooms are actually just $25. The travelers notice the five $1 bills cannot be evenly distributed among them, so they take each take $1, and the remaining $2 becomes a tip for the manager. At this moment, each traveler has paid a net amount of $9.
Three times nine is 27. Add the manager's tip and you have $29. Where did the remaining dollar go?
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
A Man of Wealth and Taste
Because the FED has printed so much money, in the time it took to conduct the transaction the $ got devalued/lost that $1 in value.
Copyright "Some Observer" |
I see you
shouldn't it be 25 for the room 2 for the tip and 1 each for the guests?
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Almost Banned Once
- Peter |
Flawed method of calculation Where did the actual $30 end up?
Of the original $30, $25 went to the motel cash register. $1 to each guest. $2 to manager. $25+$3+$2=$30 |
$30-$5=$25 total for room
$25/3 = $8.34 each for their room $8.34 +$1 = $9.34 after $1 is returned Add their portion of the tip to each: $9.34 + $2/3 = $9.34 + .66 = $10 3x$10 =$30
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
Damn, Fint. There is an easy way to resolve the problem that doesn't require division rounding.
Senior Member
You guys are a bunch of smartypantses.
There is. The math in my question is wrong. 3 x 9 is 27. Add the three dollars returned to get 30, not the two-dollar tip.
Evil Genius
No way I'd stay in a $30 a night room, or is that hourly rate?. next question?
Life is a big ocean to swim in. Wag more, bark less.
Preferred pronoun:Maestro
Wow, an oldie!
I first heard this from one of my Drill Instructors in 1974. Thanks for the memory, Supe. _
When in doubt, use overwhelming force. |
I see you
The question seemed to be why his presumed net did not add up to the original amount. Had to show the net was not correct.
That comes out with the right answer, but only by happenstance.
Kantry Member
The trick is in the line: at this point each traveler has paid $9.
Not true. They have paid $9.33 But you now know that. Best Les
Best Les My train of thought has been replaced by a bumper car. |
Senior Member
I stand by my answer. It is exactly how you account for the full $30 after starting with 3 x 9. Not coincidental happenstance. My business card says "Statistician," Fint.
It is a riddle that initially eludes most people, though.
My card says scientist...but that doesn't allow me to create my own math.
Beat that! _
Where did you account for the $2? Not even close.
To arrive at $27, you would have to have already included the $2 tip as part of the $9 each...and the additional 3 dollars would be the ones taken back (not the construct of the problem).
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender Last edited by fintstone; 11-06-2021 at 04:15 PM.. |
Sorta my point, they will put anything you want on a card. This is mine:
