Originally Posted by Bob Kontak View Post
Good job! Outstanding!
Now you need to find that poor guy at the car parts store and fill him in.
Roger that.
Old 11-29-2021, 12:55 PM
That's great news that you got it sorted!
1982 911 Targa, 3.0L ROW with Webers
Old 11-29-2021, 01:01 PM
Fingers crossed, seems to be working so far.
Old 11-29-2021, 01:12 PM
fastfredracing's Avatar
No left turn un stoned
Old 11-29-2021, 01:16 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by Scott Douglas View Post
I really don't see how the tank can allow fluid to go back into the radiator when it cools unless it is full to the brim. Even then, how would the coolant be sucked back into the radiator once the fluid level dropped?
I don't think fluid is ever sucked back into the radiator from the plastic reservoir.
It goes back into the engine through the other tube when things cool.
1981 911SC Targa
Old 11-29-2021, 01:19 PM
That's what I was wondering Bob. That cap on the rad doesn't have a means of allowing fluid back in, except that it doesn't seal down at the bottom flange, only the top one. The cap on the overflow tank won't allow fluid to flow back to the rad as the little relief valve is 'going the wrong way' so to speak.
I'd sure like to see a cross section of that overflow tank to see how they 'separate' the fluid from the vapors.
Glad you got it sorted dr. Keep us posted if things change.
Scott
'78 SC mit Sportomatic - Sold
Old 11-29-2021, 02:23 PM
I wonder if the bean counters eliminated a burp plug to save a few bucks.
Scott
Old 11-29-2021, 02:25 PM
Kantry Member
oldE's Avatar
Success!
Good man. Lots of heat for the cold weather.
Best
Les
Old 11-29-2021, 05:24 PM
Just thinking out loud
mattdavis11's Avatar
Originally Posted by drcoastline View Post
It seems this set up is correct. Flat cap on radiator pressure cap on the over flow. I had it as you said it makes sense. This system for some reason is reversed.
This morning I ma going to go through the system of filling the radiator and over flow as described above. Then I will watch and see what happens.
The caps are backwards. He should swap them around. Deep plunger on radiator, flat seal on overflow.
Seeing the tear on the seal on the radiator cap (the wrong one) I'd replace it, but it should be put it in the correct location, at the very least.
I don't know much about Xterras, but I sell radiators all day long.
91 FJ80
84 Ram Charger (now gone)
Old 11-29-2021, 07:39 PM
Matt,
Norally you would not get an argument out of me. For some reason Nissan designed this system backwards. No tears in nay of the caps and I have two brand new ones installed.
Can you get a heater core for a 1959 Edsel Corsair?
Old 11-30-2021, 01:29 AM
I can't, but vintage air might.
https://www.vintageair.com/2021%20Vintage%20Air%20Catalog.pdf
Glad you can enjoy the Xterra again. I've seen weird things, reversed impellers, bad T stats, broken T-stat, installed backwards T-stats, but I've never seen anything like yours.
It was not intended, for only your cooling system, to work that way.
91 FJ80
Old 11-30-2021, 08:28 AM
Bob Kontak's Avatar
I was at Pull-A-Part today and ran into a 2004 XTerra. Was thinking maybe I could eyeball this system.
Sigh...........
1981 911SC Targa
Old 11-30-2021, 12:27 PM
Sigh...........
Thats also a 1st Gen Xterra, we are dealing with a 2nd Gen here.
Old 11-30-2021, 01:37 PM
Yes.
Got up this morning went to my guy for inspection passed no problem then I drove to Philadelphia 80 miles on dierction, did a few things and returned. No issues.
I'm pretty confident now guys we fixed it.
I can't thank you all enough
Old 11-30-2021, 03:36 PM
