The Unsettler
Try to keep the number of splits on that leg to 1 or as low as you can.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" Last edited by stomachmonkey; 12-19-2021 at 08:34 PM.. |
The Unsettler
Well, modern mesh networks will have it. If the gear is labeled Tri Band it has backhaul which is a 3rd channel only accessible to the access points that make up the mesh. But if the access points are too far from each other you'll still not see gigabit. TCP is kinda like an old time bucket fire brigade. Imagine a line of guys passing buckets (packets) towards a fire and a separate line of guys passing empty buckets back. The return line is backhaul. Now imagine if it were only one line and they have to pass a bucket forward, empty it then the same line has to pass it back before the next full bucket can move forward. Now add in that WIFI works at the speed of the slowest connected device and there is some old B or G device attached, like that old iPod or tablet you gave to the kids, everything faster gets stuck behind it like a Ferrari on a one lane country road who just got cock blocked by farmer Joes hay wagon. That's WIFI which is why you always always always want to hardwire anything you can.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" Last edited by stomachmonkey; 12-19-2021 at 08:44 PM.. |
The Unsettler
Drop the MoCA bridge and run ethernet from it into the hub then wire up both the laptop and the printer to the hub. https://www.amazon.com/NETGEAR-5-Port-Gigabit-Ethernet-Unmanaged/dp/B07S98YLHM/ref=sr_1_3?crid=GLL1TILVCZC6&keywords=5+port+hub&qid=1639975311&sprefix=5+port+hub%2Caps%2C111&sr=8-3
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
In general, this should all work perfectly using wireless. First thing I'd do is ditch the Comcast router and get your own. Depending on the size of the house, wall types, and desired coversge area, the option is a regular dual band router or a mesh system like an Asus CT8. My garage is 100 feet from the house and I still get usable signal there.
Use the free Wifi Analyzer app on a smartphone to check signal strength and channel usage. Check for interference from neighbor's wifi. You may need to choose alternate 2.4GHz channels if there is.
Present: 1984 928S/Indischrot, 1994 968/Polar Silver Past: 1979 911SC Targa/Petrol Blue |
Many thanks Gogar... Here is my interpretation of what you are suggesting with the goal to connect the Roku and TV with a hard wire and not use Wifi at all. Is this correct?
I need to buy: - ScreenBeam module for one hook up. It looks like the usual thing is to use two. But I need just one side. Not sure which ScreenBeam to order, there are different models that seem to do the same thing. Please confirm. - Ethernet switch to get two ethernet connections one for the TV and one for Roku - buy a Roku with RJ45 input - a simple coax splitter Please add any comments or ideas. Thanks.
Sold: 1989 3.2 coupe, 112k miles |
Also thanks to Stomachmonkey. Is my latest diagram with the ScreenBeam okay?
Band.
I don't think that diagram is quite right.
again I suggest you just install Netflix, prime, and Hulu on the roku as well and ditch the internet switch and Ethernet to your (basically ancient 1st gen) clunky smart tv. So, cable from the box and everything else from roku. Save yourself a remote and some annoying clicks every day.
1983 SC Coupe 1963 BMW R60/2 1972 Triumph Tiger 1995 Triumph Daytona SuperIII Last edited by Gogar; 12-20-2021 at 08:18 AM.. |
The Unsettler
Residential broadband equipment generally comes in two flavors. A single combo modem / router or separate modem and router. Look at your router, if it has coax in and out it's a combo unit and you want to split the output. If it only has coax in then there is a separate modem somewhere that is feeding the router and you want to split on the output (house) side of that modem. EDIT. If you plan on using the ROKU you don't really need to feed ethernet to the TV, you can get Netflix, HBO, HULU etc... on the ROKU.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" Last edited by stomachmonkey; 12-20-2021 at 08:21 AM.. |
canna change law physics
On most Cable systems, you have an app in the setup screens to check signal quality.
You said you have ~150 down and ~43 up. That does not sound right, unless you are checking it with a WiFi connection. My cable is 1000 down and 40 up. I get about 920 down and 45 up. But that is checking it with a wired connection. Your cable modem can also be holding you back. Some of the older cable modems, especially the older ones supplied by the cable company, are only capable of about 300 down.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
The Unsettler
Mind you what they should do and what they actually do is not always the same thing.
I was checking it with Wifi.
It seems using MoCA and Xfinity is a known situation. I might need a different Xfinity modem/router that is MoCA enabled or capable.
https://robotpoweredhome.com/moca-xfinity/
There is more about using MoCA and Xfinity here.
https://us.hitrontech.com/learn/can-i-use-a-moca-adapter-with-xfinity-or-spectrum-internet/
In my experience, I have found the WiFi through the Comcast boxes to be horrible. I ditched my Xfinity box and replaced with a third party modem and a couple of wireless access points, and it's much, much better.
1957 Speedster, 1965 356SC, 1965 356SC Outlaw, 1972 911T, 1998 993 C2S, 2018 Targa 4 GTS, 2014 Cayenne S, 2016 Boxster Spyder, 2019 Tacoma |
I think one thing I can do is get "all" (Netflix, Plex, Amazon, HBO Max, maybe Youtube TV) my streaming apps. coming via my current Roku wireless module. I'm assuming the wifi in the Roku is better than the wifi in my very old "Smart" TV. This gets me closer to cutting the cable TV cord I think.
Agreed. I feel the solutions being discussed here are overly complex. Comcast probably makes you jump through hoops, but you should be able to use your own router and all they provide is the cable modem. Unless the house is huge or the walls are blocking signal, pure wireless should work.
