Hot water
All of a sudden, our hot water is much hotter than normal. A quick search says maybe a bad thermostat on the water heater. This morning I turned it down a bit but probably have to wait a while to see if there’s any change. The heater is probably about 7 or 8 years old. Anyone experience this or have an idea what is causing that? Thanks.—Dave
I had something somewhat similar and it ended up being a thermocouple that was going bad. It's a temperature sensor that is supposed to control the water heater operation. If they start to go bad, things can get wonky. When they actually fail, the water heater won't ignite. Pretty cheap part too
I was thinking electric...never dawned on me that it might be gas?
Which is it?
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI Last edited by stevej37; 01-20-2022 at 08:51 AM.. |
You do not have permissi
They do need to be flushed once in a while. Scale and rust builds up inside.
Better for laundry as well.
Meanwhile other things are still happening. |
I've never done it, but I understand once per year is the recommendation for flushing.
Evil Genius
an element could of developed a hot spot in the coil?
Life is a big ocean to swim in. Wag more, bark less.
The Unsettler
No advice.
Just stopping by to say I'm proud of you guys. Not one of you has called it a hot water heater yet. Well done, carry on.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
Actually, in this case one might legitimately call it a hot water heater as his water heater is needlessly heating already hot water.
But ONLY in this case :^) Last edited by gregpark; 01-20-2022 at 08:44 AM.. |
I have well water and a water softener before the water heater...never flush it.
20 years on the current one now...and still works fine.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
The Unsettler
LOL, valid point.
In the summer if the water temps from the city were warm enough we could turn off the gas to the first water heater. It was a LOT cheaper than buying some monster commercial water heater. So we indeed had a hot water heater. That last water heater was heating the water even more to mix with the incoming cold water to mix at the processor's mix valve.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
There might be iodized/zinc rods which should be changed every 3-5 years. (helps keep the internal rust down)
Kantry Member
IF it is electric, it is possible the lower element has failed. This seems to place the load on the upper element. Since heat rises, the thermostat does not feel the temp in the top of the tank and so the water in the top of the tank gets hotter than usual. Check that out.
Best Les
Best Les My train of thought has been replaced by a bumper car. |
It is electric. This AM I adjusted the thermostat down a little lower and this afternoon full hot seems to be just a little cooler than it should be. I just turned the thermostat back to where it was and will monitor it. oldE has a good explanation. Thanks, guys.
Make Bruins Great Again
Keep a close eye on things. If the water gets too hot it can cause serious burns to the skin. This can happen if you have young children or a spouse that doesn't know what is going on.
If you hear any strange noises coming from the WH shut it down. A hissing sound means that it is over pressure. It is a rare occurrence but water heaters can explode.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
^^^^ The water heater should have an expansion valve, where if the pressure builds up too high, it will flow out. That said, I suppose the valve could go bad. You can test it by lifting up the lever and hearing the water run out.
Just thinking out loud
Water leak. We don't flush, rinse, wash or clean when it's shower time. You can either freeze, or get scalded, just depends. Choice words follow.
83 944 91 FJ80 84 Ram Charger (now gone) |
Valves have gone bad but, the hissing means the valve is working. The problem there is eventually the value has to open wide if the pressure keeps building. You want to avoid a flood and/or a massive electric bill.
