Hot water
All of a sudden, our hot water is much hotter than normal. A quick search says maybe a bad thermostat on the water heater. This morning I turned it down a bit but probably have to wait a while to see if there’s any change. The heater is probably about 7 or 8 years old. Anyone experience this or have an idea what is causing that? Thanks.—Dave
Old 01-20-2022, 06:02 AM
biosurfer1's Avatar
I had something somewhat similar and it ended up being a thermocouple that was going bad. It's a temperature sensor that is supposed to control the water heater operation. If they start to go bad, things can get wonky. When they actually fail, the water heater won't ignite. Pretty cheap part too
Old 01-20-2022, 06:56 AM
I was thinking electric...never dawned on me that it might be gas?
Which is it?
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 01-20-2022, 07:02 AM
You do not have permissi
john70t's Avatar
They do need to be flushed once in a while. Scale and rust builds up inside.
Better for laundry as well.
Old 01-20-2022, 07:10 AM
I've never done it, but I understand once per year is the recommendation for flushing.
Old 01-20-2022, 07:32 AM
Evil Genius
Rusty Heap's Avatar
an element could of developed a hot spot in the coil?
Life is a big ocean to swim in.
Wag more, bark less.
Old 01-20-2022, 08:02 AM
The Unsettler
stomachmonkey's Avatar
No advice.
Just stopping by to say I'm proud of you guys.
Not one of you has called it a hot water heater yet.
Well done, carry on.
"I want my two dollars"
"Brandon Won"
Old 01-20-2022, 08:32 AM
Actually, in this case one might legitimately call it a hot water heater as his water heater is needlessly heating already hot water.
But ONLY in this case :^)
Old 01-20-2022, 08:37 AM
I have well water and a water softener before the water heater...never flush it.
20 years on the current one now...and still works fine.
98 Honda Prelude
22 Honda Civic SI
Old 01-20-2022, 08:53 AM
The Unsettler
LOL, valid point.
"Brandon Won"
Old 01-20-2022, 09:03 AM
No advice.
We used to have three water heaters in a series. So the first one just took the cold outside water and warmed it up before getting to the second one and that heated it more for the final water heater. Then it could flow out to the film and paper processors and supply a continuous supply of warm water. The film processors needed 100 degree water for hours on end.
In the summer if the water temps from the city were warm enough we could turn off the gas to the first water heater.
It was a LOT cheaper than buying some monster commercial water heater. So we indeed had a hot water heater. That last water heater was heating the water even more to mix with the incoming cold water to mix at the processor's mix valve.
Old 01-20-2022, 10:11 AM
john70t's Avatar
Mine is probably due as well
There might be iodized/zinc rods which should be changed every 3-5 years.
(helps keep the internal rust down)
Old 01-20-2022, 11:16 AM
Kantry Member
oldE's Avatar
IF it is electric, it is possible the lower element has failed. This seems to place the load on the upper element. Since heat rises, the thermostat does not feel the temp in the top of the tank and so the water in the top of the tank gets hotter than usual. Check that out.
Best
Les
Best
Les
Old 01-20-2022, 11:20 AM
It is electric. This AM I adjusted the thermostat down a little lower and this afternoon full hot seems to be just a little cooler than it should be. I just turned the thermostat back to where it was and will monitor it. oldE has a good explanation. Thanks, guys.
Old 01-20-2022, 04:20 PM
Make Bruins Great Again
Por_sha911's Avatar
Keep a close eye on things. If the water gets too hot it can cause serious burns to the skin. This can happen if you have young children or a spouse that doesn't know what is going on.
If you hear any strange noises coming from the WH shut it down. A hissing sound means that it is over pressure. It is a rare occurrence but water heaters can explode.
Joe
Old 01-20-2022, 05:31 PM
A930Rocket's Avatar
^^^^ The water heater should have an expansion valve, where if the pressure builds up too high, it will flow out. That said, I suppose the valve could go bad. You can test it by lifting up the lever and hearing the water run out.
Old 01-20-2022, 05:45 PM
Just thinking out loud
mattdavis11's Avatar
Water leak. We don't flush, rinse, wash or clean when it's shower time. You can either freeze, or get scalded, just depends. Choice words follow.
91 FJ80
84 Ram Charger (now gone)
Old 01-20-2022, 05:48 PM
A930Rocket's Avatar
I miss MythBusters.
Por_sha911's Avatar
Valves have gone bad but, the hissing means the valve is working. The problem there is eventually the value has to open wide if the pressure keeps building. You want to avoid a flood and/or a massive electric bill.
Joe
Old 01-20-2022, 07:13 PM
