Gon fix it with me hammer
911's hell, they are plenty modern enough and seals are very doable..
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
I'm saying...if you have a non-leaking engine with dino oil....why switch and cause leaks?
I understand the benefits of syn.....but why cause problems if your car doesn't leak?
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
it will leak eventually, I'de say those that leak, leaked because them seals were done and should have gotten new seals as well as new oil
That the new oil clears up gunk in the engines, and also gunk in the seals That's what does it, them additives that gets the gunk to release and come out... doesn't mean no new oil is a best solution.. hell, you still have the gunk in the rest of the engine as well as in them seals I'de rather have the the better oil in and gunk out of the oil galleries, and everywhere else and if a seal leaks, a new , better seal to replace it
Think you'll find it's the other way around. In Europe, there are very strict laws regarding what can be labelled "synthetic". And that's where the Liqui-Moly I put in the turbo comes from (although I was very happy with Rotella for years).
In the US, it's less strict; some (who know more about the topic than I) have said that it is almost a marketing term now. Which isn't to say that you can't get full synthetic in the US - but, for example, ~20 years ago US Mobil-1 could not have been sold in Europe as synthetic; Mobil 1 formulated for the European market was a full synthetic, and US Mobil 1 was apparently not. This was stated on the massive oil thread in Technical, and I'm certainly not going to go looking for that post again... However: Quote:
'77 S with '78 930 power and a few other things. |
Free minder
I noticed that synthetic oil really stinks when it burns on the exhaust. I also think it makes leaks much worse, or creates leaks that did not exist before.
For the 911, I switched back to 20w50 Castro classic oil with extra zddp in it.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/ 2014 Cayenne platinum edition 2008 Benz C300 (wife’s) 2010 Honda Civic LX (daughter’s) |
Still here
Check your FLISM.
Banned
because your engine already has the problem if it leaks just by putting in better oil.
^^^ I would rather not go looking for problems...as far as a clean engine goes.
The dino oil I use in my 911's has worked fine for the 20 and 25 years I have owned them.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI Last edited by stevej37; 01-25-2022 at 11:24 AM.. |
I see you
Delivered by last night!
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Bollweevil
Agree ^^^^^^ Should have been more clear in my original post. The dino oil I purchased at the Mart was for my lawn tractor (a 18 YO JDeere LT160 with over 1200 hours on it). I have been using Mart branded 10W-40 in it since the first oil change. It has no leaks, doesn't burn oil and still runs good. NO WAY was I changing to synthetic at this point in time. My apologies ...
Jack 74 911 Coupe 2.7L - K21 Option - S suspension Last edited by 74-911; 01-26-2022 at 01:01 PM.. |
Synth leaks are another internet myth.
Debunked. It's amazing how long misinformation lives on. It is a wives tale. When synthetics first came out, like 30 years ago, they could affect seals and cause leaks. Oil manufacturers quickly figured that out (they work closely with car manufacturers) and put additives in to stop that.
1986 Bosch Icon Wipers coupe. |
Still here
Dino about that ! |
Go forward to the 80's when I was racing the big tracks like Willow, I used oil that actually helped with the burn. If you weren't careful and you were running your CC's very close to the rules, you could go over just because of the build up. These were hour long races so you couldn't run as lean as you might in a sprint. So you got some carbon deposits. IDT anyone was using a full synthetic then. I'm the last guy you want to ask about molecule sizes of various oils. I just know what I've seen and done, and the more complex oils were needed when the engines got more powerful. Original synthetic starts out with a smaller molecular formulation according to what little I know. Today's oils are very complex. When stretched to as little as 40:1 in racing gas, that oil has to hold up (or hold together, as in polymers — I am not saying oil is a polymer — it's just an expression). Crankcase oil would be horrible in a racing 2-stroke motor. |
