Information Overloader
For me, the best occasional-use chainsaw is my neighbor's.
Yellow chain is simply not the green "safety chain". Yeah, KC is right - the yellow chain cuts a lot faster. But with your propensity to hit nails, I don't think that matters as much.
Stihl "Moto Mix" is what you want to put in your occasional use saw. Pour the gas out of the saw if you're going to store it. You can put a shorter bar on if you have a Farm Boss or some other heavy chain and just want to cut little trees. Otherwise I don't see any need to mess with changing a bar on a occastional use saw. |
You can thank Stihl lawyers for them only recomending their green coded "safety', or semi-chisel'd chains. Go back and read my post where I show a pic of 4 saws.... the bottom baby Echo's chain didn't come in a package ... the Stihl (and Echo) dealer "made it" from their big roll of chains .... you can see the yellow coded link on the full chisel chain. You ain't never gonna hurt your Stihl by chain choice .... prolly the inverse tho' .... full chisel just cuts better .... matters more on small displacement saws imo. Be safe with your technique, I don't cut with the tip and have never had a kick-back fwiw.
Yes, that's the fuel that I am using. It's expensive, but it's not like I'm going through 5 gallons a week. I wasn't thinking about changing to a different sized bar. I was just going to have an extra. They aren't expensive, and spare parts are nice to have.
....edited: Pre-mix is absolutely the way for you to go.... But my latest Stihl back pack blower is a gas hog .... I used a gal. last Saturday
I see you
Yellow vs green is full chisel vs semi-chisel?
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Yep .... Oregon (makes fine stuff) doesn't usually have color codes, and sometimes calls the semi-chisel ones "camphored" .... the full chisel has a 90 degree angle on the teeth bend .... you can see the difference in the profile. It's those chains with itty-bitty teeth that you really don't want ... that's what came on my pro level 13' Stihl pole saw (10" bar) .... wasn't worth a damn.
The replacement bar wasn't cheap ... around $75 and another bit for the chain. Transformed the saw into a beast from a disappointment .
I see you
I’ve started using my Milwaukee 18V reciprocating saw for trimming tree limbs up to about 5” diameter with a long blade. I use the Stihl for the larger jobs. Works surprisingly well for me.
Hugh Lindberg 1972 911 1970 Alfa Romeo 1300 GT Junior |
