But they are expensive. The set in the photo cost me about $70 AU. EDIT: ... And what Tobra wrote above. |
Get up in the morning and spray Kroil on every fastener. Go to beach for the day. Repeat next day. Third day try to take them out with a proper allen wrench. If they don't come right out repeat spray and beach time. Kroil will wick into the threads and they will come out.
These look good, because Allen style can easily deform the holes which make them harder to use in the future. And Allen head bolts are harder to replace than a regular hex head bolt. |
Get a pencil torch and just hit the head so you don't melt the paint on the door. All you are trying to do is break the seal. Then anti seize.
Heat, PB blaster
And a lot of curse words, some even made up |
All the above, plus when you first put the tool to the fastener, you might try to tighten it juuuuuusssssst a little, to see if you can release the initial stiction.
You just want to hear that satisfying 'pop'. |
| All times are GMT -8. The time now is 07:15 PM. |
