What Is This Thing Called?
For the life me I cannot think of what these are called…those articulating, “swing-arm” clamps which are threaded on one end - with this threaded end fitted with a thumb screw…so when this threaded end is swung into a “receiver plate,” the thumbscrew is then tightened until the appropriate (desired) locking force is achieved. Anyone?
Model Citizen
Are you describing Kant Twist clamps?
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
Almost Banned Once
Toggle Clamp?
- Peter |
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
Nope (but thanks!).
The receiver plate features a v or u shaped open end, into which the threaded shaft with thumbnut is swung, then the thumbnut tightened against the bottom flange of the receiver plate. Hmmm...maybe I'll draw a picture and post it. |
I think that'll help a lot.
Platinum Member
![]() Hold down clamp?
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Here it is! I knew I had something around someplace with this type of locking mechanism…here in the form of my old Leitz tripod leg-clamp accessory:
![]() ![]() But what I need is something which operates on this principle, to replace a “fixed adjustment” hook and eye scenario. Here is my application...for our cute/lovable (and sometimes naughty) rescue-up, Lena: ![]() I have crafted, from plywood, foam, and faux leather, a doggie seat, which fits into the otherwise rather uncomfortable rear seat-wells of my 944: ![]() The doggie seat sets upon two carefully shaped plywood panels, each affixed via. existing seatbelt bolts. Currently, the seat is held down with two hook and eye locks - which to work effectively need to be adjusted exactly, but the adjustment of the whole “system” tends to deviate over time, and it would be great if I could tighten things down a bit more. Here’s the kicker: yes, I could simply install angle brackets to make this more solid…but I like the idea of being able to quickly unclip/remove the doggie seat, thus the need for a mechanism which allows such easy removal, and also allows for some adjustment to clamping force. At any rate…any ideas? Thanks! |
How about this or a couple of Lindells My Pillows?
Jeff Hail "All men dream: but not equally. Those who dream by night in the dusty recesses of their minds, wake in the day to find that it is vanity; but the dreamers of the day are dangerous men, for they act their dream with open eyes, to make it possible" |
Kantry Member
I think that is called a split block clamp.
For the pup, why didn't you just fold down the rear seat backs? Best Les
Best Les My train of thought has been replaced by a bumper car. |
![]() I use this. It goes from truck to car. He's very comfortable in it like a crate. Holds him in place too but he's never ridden in the 911. He doesn't like getting tossed around violently |
