Zombie
What Is This Thing Called?
For the life me I cannot think of what these are called…those articulating, “swing-arm” clamps which are threaded on one end - with this threaded end fitted with a thumb screw…so when this threaded end is swung into a “receiver plate,” the thumbscrew is then tightened until the appropriate (desired) locking force is achieved. Anyone?
Old 04-23-2022, 05:43 AM
Model Citizen
herr_oberst's Avatar
Are you describing Kant Twist clamps?
Old 04-23-2022, 05:57 AM
Almost Banned Once
sc_rufctr's Avatar
Toggle Clamp?
- Peter
Old 04-23-2022, 06:13 AM
MBAtarga's Avatar
Mark
'83 SC Targa - since 5/5/2001
Old 04-23-2022, 07:07 AM
Zombie
Nope (but thanks!).
The receiver plate features a v or u shaped open end, into which the threaded shaft with thumbnut is swung, then the thumbnut tightened against the bottom flange of the receiver plate. Hmmm...maybe I'll draw a picture and post it.
Old 04-23-2022, 08:37 AM
I think that'll help a lot.
Old 04-23-2022, 09:22 AM
Platinum Member
dad911's Avatar
Hold down clamp?
Old 04-23-2022, 03:45 PM
Zombie
Here it is! I knew I had something around someplace with this type of locking mechanism…here in the form of my old Leitz tripod leg-clamp accessory:
But what I need is something which operates on this principle, to replace a “fixed adjustment” hook and eye scenario. Here is my application...for our cute/lovable (and sometimes naughty) rescue-up, Lena:
I have crafted, from plywood, foam, and faux leather, a doggie seat, which fits into the otherwise rather uncomfortable rear seat-wells of my 944:
The doggie seat sets upon two carefully shaped plywood panels, each affixed via. existing seatbelt bolts. Currently, the seat is held down with two hook and eye locks - which to work effectively need to be adjusted exactly, but the adjustment of the whole “system” tends to deviate over time, and it would be great if I could tighten things down a bit more.
Here’s the kicker: yes, I could simply install angle brackets to make this more solid…but I like the idea of being able to quickly unclip/remove the doggie seat, thus the need for a mechanism which allows such easy removal, and also allows for some adjustment to clamping force.
At any rate…any ideas? Thanks!
Old 04-24-2022, 07:15 AM
Jeff Hail's Avatar
How about this or a couple of Lindells My Pillows?
Jeff Hail
"All men dream: but not equally. Those who dream by night in the dusty recesses of their minds, wake in the day to find that it is vanity; but the dreamers of the day are dangerous men, for they act their dream with open eyes, to make it possible"
Old 04-24-2022, 09:35 AM
Kantry Member
oldE's Avatar
I think that is called a split block clamp.
For the pup, why didn't you just fold down the rear seat backs?
Best
Les
Best
Les
Old 04-24-2022, 03:31 PM
I use this. It goes from truck to car. He's very comfortable in it like a crate. Holds him in place too but he's never ridden in the 911. He doesn't like getting tossed around violently
Old 04-24-2022, 06:05 PM
