If you want to turn on a light from two different locations like two entries into a large room, long hallway, top and bottom of a stairway etc.
As we all agree, that one solution only solves half the problem, you want to be able fully operate it from both locations. |
You are correct in your thinking of how it's supposed to work.
Fault sounds like some sort of short in the line. I've had one where both switches had to be just right in order to work.
Guy '87 944 (first porsche/project car) |
Gon fix it with me hammer
100 meter roll is 130 bucks or so for 1.5mm copper . Which is fine for lighting 2.5 is more expensive Either way. The both off for off setup wont save much wire. For much annoyance qnd little useful functionality
Stijn Vandamme EX911STARGA73EX92477EX94484EX944S8890MPHPINBALLMACHINEAKAEX987C2007 BIMDIESELBMW116D2019 |
Retired in Georgia
I will take a bright light and see if either toggle in embossed with ON or OFF, and might even pull the plate an peer inside to see what back magic is contained within. (I know, I know, don't let the smoke out...I'll be sure to close the 'smoke valve' in the electrical panel first).
I've got five kids, an Italian wife, and I (used to) write about lawn mowers. You think you have problems? -Robert Coats |
Platinum Member
Or put in a smartswitch and say 'Hey Google turn on the Hallway Light'
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Location: behind the redwood curtain, (humboldt county) california
Use your volt ohm meter to verify both switches and wire continuity
I just went through a 3 way system, next door.
First you need to determine which side supplies the circuit, (always hot and consistent nutral/ground). Then run a continuity check, to verify no shorts of opens. Bench test your switches, not all of them have black "commons", or they may not be in the same places on both switches. This can get confusing and i think this is one of the major sources of 3 way inconsistencies. chris, |
"Only God and electricians can make light"
1980 911 - Metzger 3.6L 2016 Cayman S |
Misunderstood User
+1 There is only one way to do it, anything else is mis-wired. The mis-wiring appears more common than I would have thought. My son bought a home built in 2006 and 3 swathes in the home were mis-wired.
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
Takin' hard left turns
I just remodeled my kitchen and wanted to control the "stadium lighting" from three locations. Turns out there's such a thing as four-way switches; didn't know that! You need four-way switches in the middle of the circuit bookended by three-way switches. I was heartily impressed with myself when I'd finished and found it worked like a charm. I did end up buying a crap-ton of 14-3 wire though.
see 3-way Light Switch Confusion...
