This is basically the one we have, but the center divide in ours is taller. I love it. Black granite; put in black drains, but they've got some chipping and will need to be replaced.
https://www.build.com/product/summary/1628789?uid=3867107&jmtest=gg-gbav2_3867107&inv2=1&&source=gg-gba-pla_3867107!c1707673110!a69500367354!dc!ng&gclid=EAIaIQobChMI4LCx-KeP-AIVKHZvBB1HrgREEAQYFyABEgIRg_D_BwE&gclsrc=aw.ds
Guy '87 944 (first porsche/project car) |
The Unsettler
Before I got my first ever double sink I always thought I wanted one.
Got one, can't stand them. Both sides are barely large enough to be useful. Give me a big deep farm sink and I'm good to go.
"I want my two dollars" "Goodbye and thanks for the fish" "Proud Member and Supporter of the YWL" "Brandon Won" |
I like the farm sink look; wife hates it. Don't know why, and know enough not to bother asking.
![]() Cheers
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 Last edited by Jeff Alton; 06-02-2022 at 07:43 PM.. |
The Unsettler
Jeff, that's the way they are suppose to be mounted with the drain toward the back. Reason is that there are more usable space near the front instead of a hole when you go and put down a cup or dish. Not a big deal really, but that's the idea.
That's right, 100% Especially if you got one of them demon grindy thingies in there.
The faucet looks exactly like the faucet that was in the cabin that we rented out this past week for a little family vacation. It worked fine. If you use the button to go from stream to spray, I suspect the rubber will be the first thing to go, but I'm sure it'll probably be years.
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() Last edited by masraum; 06-03-2022 at 02:41 PM.. |
You do not have permissi
Make sure the drain pipe after the p-trap has a downward slope to the wall drop. That prevents a lot of problems later on. Toilet paper wrapped around pipes finds leaks. And yeah, demon grinders are an open invitation to cut up several cantaloupe rinds and press them down into the drain with metal objects using force. I've got the same faucet and it's been okay for a couple years now. Not super strong but no problems so far. I like the high pull-down to use spray when needed (but too much water spray in my case and not clean-able) Since the sink is on tile (i.e irregular surface), I'd suggest buying a quart of plumber's putty and roll a nice and even .5-1" tube and press that in around the perimeter towards the outer lip. This will make an internal seal to keep water out of the cabinet underneath which will do damage. The extra putty which presses out can be scraped clean with a plastic knife. With a little acetone on a rag to remove excess it can be clear-caulked from the outside for a double seal. I usually cut off minimal tip on the caulk tube and push it forward into the gap slowly. You can sandpaper the tip to make it nice and round. Watch for caulk on the edges and move faster if too much bubble out on the sides. Stop, clean, and start over if you get the triple lines. Squeeze a little out and use a small screw with blue tape to seal for later use. The left counter is for dirty dishes dump in a large pile. The left sink is for soak/wash. Dirty side. The right sink is for rinsing or cleaning veggies. Clean side. The right counter is for air drying everything that needs to be hand washed or too big for the 18" dishwasher. That formula is what seems to work in my little kitchen at least. ![]()
Meanwhile other things are still happening. Last edited by john70t; 06-03-2022 at 05:43 PM.. |
Thread Tools | |
Rate This Thread | |
