Smart thermostat
I have a new smart thermo that I want to replace my old one with. There are 4 wires. 2 are obvious where I connect to, the other two I’m not sure. Attached are the existing set up (with wires) and the second is the new panel. Any suggestions? Thanks.
Old 06-12-2022, 02:27 PM
Old 06-12-2022, 02:28 PM
Old 06-12-2022, 02:29 PM
My other ride is a C-130J
RNajarian's Avatar
If my memory serves me there is at least a third wire referred to as the “C” wire.
If there are only two wires attached to the old thermostat you will need to connect at least one additional wire to the thermostat and furnace.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic
2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer
Previously Owned Art from Stuttgart
2000 Boxster -1983 911 SC Cab -1984 944 N/A
Old 06-12-2022, 02:32 PM
RNajarian's Avatar
The wiring to my thermostat looked something like this. . .
You may need to run an additional wire to the furnace from the thermostat.
Old 06-12-2022, 02:51 PM
Sorry, 5 wires. White, green, red, yellow and Orange. I’m assuming the yellow and green go into Y and G. Red likely RC since originally is in R that has a bridge to RC. Orange to O/B. White I’m not sure.
Old 06-12-2022, 03:17 PM
Band.
Go to the furnace end and check the labeling on the furnace end and see if you can make sense of it with your new thermostat
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 06-12-2022, 03:19 PM
Send a message via AIM to fintstone
Without knowing more about your new panel (brand/model), I would think:
Black to C
Yellow to Y1
Red to RH with a jumper to RC
Orange to O/B
Green to G
White to W/E
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo
http://www.pelicanparts.com/gallery/fintstone/
"The problem with socialism is that you eventually run out of other people's money"
Some are born free. Some have freedom thrust upon them. Others simply surrender
Old 06-12-2022, 04:12 PM
Wife figured out going on App. Thanks for the help.
Old 06-12-2022, 05:55 PM
