I just had this on vacation in Mexico. After the water was shut off by an unknown party, the toilet was “off.”
A plumber fixed it. I can’t help here. He said something about air bubble and high pressure. I was on vacation. I ignored him and had another beverage. |
And it's weird that one day it was "normal" and the next day it wasn't. But sometimes coincidences happen and stuff happens spontaneously. |
I'll make sure there's no sewer lake under the house, and give things a thorough check. Earlier, I took off the tank lid and fiddled with the mechanism, pushed, pulled, twisted, wiggled. The mechanism giggled a little, and I've found the tank back to normal twice since then. Maybe it was a combination of the water issue we had and the hard water causing a mineral build up that my foreplay shook loose. |
Only if the water is shut off to not allow the water to flow into the bowl. Once it reaches the upper limit of the ptrap, the level should always be the same. Wax ring was my first guess but it may be unlikely now that I thought about it more. The real problem maybe your fill valve, or fill tube. It may be adjusted to shut off too soon causing not having enough water to fill the bowl back to its normal level. The other long shot maybe your vent is clogged with leaves. If the bowl cracks, you will see water on the floor as well as under the house. They are pretty simple devices, keep at it. Its abnormal to have low water lever like that
Do you have two toilets back to back? We do and when one is flushed it will pull a vacuum on the other and pulls some water from the bowl. Or I think that is happening.
On a really windy day, the air blowing over the roof vent can cause the water in the P trap to slosh a bit drawing water out of the bowl. Depends on the direction of the wind, the roof line, pipe lengths and things like that. Has not been very windy lately so I doubt it is that.
I've always wondered about that.
Theoretically there shouldn't be any vacuum in the drain because of the vent stack, but that could be blocked by a chipmunk or leafs. The flush action does work on vacuum and air being sucked passed the base o-ring would affect the consistent transfer. |
There is probably a small tube coming off the valve. Make sure the clip holds the end so that the water goes down the 1" dia. tube coming up in the tank. This is what fills the P trap/bowl to a constant level.
I know you're a DIY type, but since you had a pro recently install it, have you considered calling him and asking about it? Any pro (worth using) should acknowlege something is amiss, and stand behind their work. Good luck!
Problem solved. When I got the water going again, we had to run the water for a bit to get the air out of the system. When there's air in the system, you often get little pressure spikes as you work through the bubbles.
I was looking inside the tank, and noticed that the refill hose was filling the canister, but off to the side, not down the middle, and there was no clip to hold it in place. I thought, if it was pressed into the male flange in the middle, it wouldn't need a clip. I stuck the hose in the hole and flushed and everything worked as expected. I think one of those pressure spikes from the bubbles in the system blew the little hose out of the hole. Not my pic or notations, just one that I found online. But the part where the refill hose goes into the receptacle in the middle of the red circle is the end that popped out. https://support.kohler.com/hc/articl...4/mceclip2.png |
Ok. Since I added noise to the conversation. Let me give input that could help.
1). Could the shut off have dislodged debris? Maybe small gravel that affects the float valve? I would start here. Replace the valve or disassemble at a minimum to inspect. (There was considerable gravel in the faucet aerator after the shut off in Mexico. ) 2) bleed the system. Purge air and junk from the line. I vote for the shut off dislodging solid chunks that are messing up performance. Good luck. |
Awesome! Next time I have a plumbing issue.... I'm calling Steve :)
On a really windy day, it is just normal. |
When I drop a big load the water level almost overflows the bowl...
The reason that the water level changes is because of the C.H.U.D.s, obviously.
I think it has to do with the proximity and gravitational pull of the nearby moon.
| All times are GMT -8. The time now is 09:20 PM. |
