can't plug one into the other when they do not correlate.... different concepts.
I've seen a whole 700 chem class struggle with that concept last semester. which reminds me of the arguments here.
dolor et pavor Copyright |
Don’t bring up chemistry, next we will be talking about moles…
I see you
Well then if we're discussing gravity we need to start talking about one of my favs the meter/second/second...weeeee! Oh oh how about Newtons kg-2 m2?
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Information Junky
Or imagine a planet of 100% water, with the block of steel at the center. What would be the big gravitational force on that block of steel, and which way would this gravitational field accelerate that block? ![]() Smart ass! Of course saying that weight doesn't change leaves ambiguity about the weight measured. I mean, if you jump on a trampoline, are you not weightless in the air? There are no forces holding you in the air. You posses both mass and acceleration yet for a moment you are weightless - just as you would be in space.Back to the ocean thing... If, as an engineering exercise, the questions arose of, how much force would be needed to suspend a 100_lb ingot of Aluminum in a freshwater lake? would you answer 100_lbs ? Yeah, you probably would. -LOL But would you show your work... SGAl = 2.6, Suspension Force = 100-(100/2.6)= 61.54_lbf Buoyancy Force = 100/2.6 = 38.46_lbf Total Force = Buoyancy Force + Suspension Force = 100_lbf Or would you leave those details of the answer hanging until your teacher marked "100_lbf" wrong? Not that I would ever do anything like that.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Pop quiz.
What’s the value of gravity of the center of the earth? |
Information Junky
Are we assuming a static spherically symmetric perfect density?
And/or do you mean center of mass?
No, I mean the gravitational constant at the center of the earth.
Assume the earth has an even distribution of mass, or just don’t worry about the rounding error. |
Information Junky
Gravitational constant is the point value, not to be confused with the small g of gravity at that point.
Information Junky
...point value of the total mass.
Used for planetary interaction calcs and such.
OK, smart Alec, give me the answer for both big G and little g.
Information Junky
Ok, the G is earth-sized massive whereas the g is zero.
If we had a tunnel thru the center you can imagine that you would fall to the center, with diminishing g as the center is approached and Coriolis kicking your ass the whole way down and back the other side a ways.
R&D guy
Location: the border between the states of inebriation & confusion
Sorry, but my first thought was: "Ok, a thread started by someone who didn't pay attention in science class and missed the explanation of weight versus mass..."
If you accept the equivalency principle of ma=F=mg, then "weight" is the total sum of forces on an object to keep it un-accelerated in the local coordinate system. That would mean that the buoyancy force is absolutely part of it, and the weight of an object within water is less than the weight of that object outside of water...in fact, a floating object has zero weight.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
I think you ASSUmed physics was the only way to weigh in on this question.
I see you
clever bugger you are!
Really? What other branch of science might deal with this question?
Information Junky
How about Ocean science?
I've done some design work for deep (miles down) submersibles. Controlling neutral buoyancy is kind of a big deal.
Information Junky
Check out syntactic foams which resist this...
Evil Genius
Seems like someone couldn't find her G Spot.
Life is a big ocean to swim in. Wag more, bark less.
Id say it only seems like things might weigh less because they fall to the bottom slowly. Both because there is still air in them and the resistence of the water
82 SC , 72 914 |
