Make Bruins Great Again
I don't think that is correct. Oil change in the summer: the new oil pours very quickly. In winter (the same oil) pours much slower. It is thinner when warm.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
Mighty Meatlocker Turbo
Quote from Amsoil link:
"...we can simply say this: most oil sold today is multi-viscosity. The first number refers to its viscosity, or resistance to flow, when cold (e.g. 5W). Think of the “W” as standing for “winter.” The lower the number, the faster the oil will flow when cold, meaning a 5W-50 oil will flow faster at startup than a 20W-50 oil. Multi-viscosity oils use chemicals called viscosity index improvers to allow the oil to flow differently at different temperatures. For example, they allow a 20W-50 oil to behave like a 20-weight oil when cold and a 50-weight oil when warm." https://blog.amsoil.com/should-i-run-multi-weight-or-straight-weight-oil-in-my-muscle-car/ Rawknees: "the higher the number on the right the more resistant it is to heat related thinning (it does not actually thicken when heated)" More than resists thinning as it becomes more viscous or thicker than when cold. I don't think the difference is easily observable as Por_Sha claims. I'd swear hot oil of the same rating is thinner based on observation but it's not.
Bob S. '87 911 ("Hardtop" per neighbor) |
![]() If it is this bad, no cleaner or magic crap in a can will help. When my original 305 in the El Camino had 300,000 miles of regular use, and regular oil changes the oil was so clean that when I did an oil change, it was hard to see the oil level on the dip stick as it was almost clear. I took the old 305 apart just because I was curious. This is the innards of the engine after 300,000+ miles. The rings were worn, and the valve guides were worn out. It ran just fine, but I hated the smoke, and $1,700 fixed it with the new 350.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
i just bought an 08 535i that needs turbos. when i drained the oil it did not look good. looked like it had water in it. i sent the oil off and sure enough it did. water NOT coolant. most likely from short dirves and condensation build up. the engine wear was good. anyway. i was going to remove the drain plug and pour a qrt or two of new oil in it and let it "flush" out anything sitting in the pan. i did look up engine flushes. i have "heard" you can use kerosene, even kerosene with no oil. but naa. not worth it. i dont feel good about it. i did one on a 280z when i was a kid. add a qrt tot he oil. get it hot and drain. let me tell, even though it was mostly oil, it was a "good" parts cleaner. i dropped something in the pan and when i got it out it was clean.
When I pulled the valve cover and the oil pan on my 05 330, both were clean and tinged gold. ~165k on the clock. I change the oil before every track weekend. So, probably four or five times a year.
I’ve only owned it a couple years, so I don’t know the previous history, except T77911S flogging the snot out of it at the track!😂 ![]() ![]()
At the local shop a tractor was brought in and they could not drain the oil as nothing cam out when they took the plug out. Then the mechanic stuck a screwdriver in and it stuck in the goo. Turns out it had used a bit and the owner kept topping off with Slick 50.
Brent The X15 was the only aircraft I flew where I was glad the engine quit. - Milt Thompson. "Don't get so caught up in your right to dissent that you forget your obligation to contribute." Mrs. James to her son Chappie. |
Team California
those are pretty clean but my 1980 Scirocco w/ 32k miles takes the case. Here is what it looked like under the valve cover after sitting for 20+ years:
![]() ![]() The other thing that you want to look at when buying a used engine, (or a vehicle but it's harder to see assembled), is the coolant passages. Nothing tells you more about the maintenance history and prognosis going forward than that. And the oil passages, of course.
Denis |
