Arizona_928's Avatar
Anti-seize. I had a cat fuel filter gall to the base due to lack of anti-seize....
dolor et pavor
Copyright
Old 10-12-2022, 09:55 AM
For my 911, I always put it on the lift, remove all 4 wheel and tires and throw them and the new tires in the back of the El Camino and off to a local independent Porsche only repair shop. They have a new tire machine, and get the new tires mounted with zero damage to the wheels and road force balance. No one but me removes and replaces those aluminum nuts.
Oops. Titanium
Old 10-12-2022, 10:37 AM
Registered ConfUser
I’ve used anti-seize on lug threads for 40 years without a single issue. And without a single seized lug nut. I’m convinced.
Mike
Old 10-12-2022, 10:41 AM
The older porsche lug nuts are Aluminum T6 at least the classical black "alloy" lug nuts holding on so many fuchs and similar
18 Cayman GTS
Old 10-12-2022, 10:43 AM
sugarwood's Avatar
Subaru is known for cheap grade lug studs.
You may also want to research replacing the lug nuts with aftermarket like McGard
1986 Bosch Icon Wipers coupe.
Old 10-12-2022, 12:19 PM
Like I said, oops…I was always told they were titanium. Misinformation I guess.
Old 10-12-2022, 12:33 PM
Counterclockwise?
My problem is swollen nuts. But you probably don't want to know
Rod
1986 Carrera
2001 996TT
Old 10-12-2022, 02:00 PM
Almost Banned Once
sc_rufctr's Avatar
I've always used a very small amount of plain old grease on lug nuts.
I also apply a thin smear on the matting surfaces of the wheel and hub and I've never had an issue.
- Peter
Old 10-12-2022, 03:43 PM
Team California
speeder's Avatar
Same. The other tip is to always make sure that the threads are 100% clean, (this goes for all fasteners in my OCD world). I have a collection of those copper bristle tooth brushes that I use constantly and use WD40 liberally as a solvent to wash away dirt and grit.
There was a hilarious thread ~20 years ago on the 911 tech board about whether people re-torque their lug nuts at the track...tried to find it...comedy gold from some OGs.
Maybe someone with better search skilz can pull it up.
Denis
Old 10-12-2022, 04:43 PM
Make Bruins Great Again
Por_sha911's Avatar
What I was thinking right from the start. Also do a quick inspection of the threads to see if any are damaged.
Joe
Old 10-12-2022, 05:51 PM
I've done the same thing. No issues with nuts coming off and no seizing or galling and low wear. The question of using or not AS on lug nuts/bolts has many threads and opinions on the web.
I like to avoid issues - e.g. cold rainy night and getting a flat and have a hard time getting a wheel off.
Sold: 1989 3.2 coupe, 112k miles
Old 10-12-2022, 06:00 PM
This is what I do.
Brent
Old 10-12-2022, 09:45 PM
