Information Junky
...leaving the train station at 12 o'clock....
![]() Yes, you included the part about pressure, but only after you reinforced "downward throw" twice. And THEN you said "its about pressure distribution, not "down flow" - My focus was about that inconsistency of yours.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
Sent from my SM-G988B using Tapatalk |
Banned
"net doward throw is a simplified answer, and not a true determiner. useful, but not the be all end all determiner. lift is a force, a force is generated by pressure over an area. you can generate a pressure differential with the shape of the wing, or with the angle of the wing, but both methods create a pressure differential, higher on the bottom, lower on the top (until stall)." emphasis added. like its very clear you didnt read the post and decided to attack me over your failure to read the post. |
I have this nightmare..... I'm sitting in the middle seat with Island on one side, CP on the other....
I think to myself .... but out loud.... "I wonder what makes this airplane fly?" They better serve hard liquor or else !
Banned
![]() he just read the first sentence of my post, because we disagree politically, he stopped there, assumed it was wrong, and then attacked me for what he thinks i posted. and now he has to figure out a way to mis-read my very clear post to make it reasonable to conclude that i said literally the exact opposite of what i said. the secret is that i just did basic unit analysis. lift is a force, and forces are computed using pressures over areas. therefore the lift generated is based on pressures. now those pressures can be achieved several different ways (as i detailed), and that can be based on having a "down flow" and even is most often created by having a "down flow" (ie AoA) but that does not mean that downflow computes the lift accurately. it doesn't. because lift is based on pressure. |
mjohnson, I hope you have learned what you needed to know about lifties
![]() I am going to close this because the airplane has taken a dirt road...what a place. This was a thread on aerodynamics FTLOG. BTW, my partner has an MS from Stanford in Aero...I just got off the phone with him. He can help!
1996 FJ80. Last edited by Seahawk; 10-26-2022 at 12:46 PM.. |
