Brick layer advice
We have some minor brickwork needed on our mailbox. I have "a guy" coming over to do it on Wednesday. My question is not about the brickwork, but the temperatures. Mortar is mixed with water. Will it "dry" or set in just hours?
Wednesday is going to be 48 degrees and partly cloudy. But Wednesday night, the dang Russian Siberian air gets here and some forecasts show a low of 2 degrees. It seems crazy to have anything mixed with water with crazy cold temps on the way and it does not get above freezing until Sunday afternoon for a while. The below freezing overnight.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Cement is exothermic when drying, so I assume the cold may not impact it too much. It may not be ideal, but my guess is that it's probably not a show stopper.
I remember some show, maybe mythbusters or something like that talking about the old "cement shoes" and how your feet would be burned in the process. I don't know that it gets THAT hot.
https://www.madgetech.com/posts/blogs/maintaining-the-ideal-temperature-during-concrete-curing/
I've seen some of the neighborhood mailboxes that after the brick work is done...it is wrapped with black plastic and left on for a day or so....when the temps are low.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
More interesting info with lots more details. I think one of the items says "keep it above freezing for 24 hours".
https://www.thespruce.com/expert-tips-on-how-to-cure-concrete-in-cold-weather-845024 Maybe you could build an insulated box around your mailbox and toss a heater in it. It seems like it's not going to be an ideal situation.
https://goodmansonconstruction.com/concrete-curing/
Platinum Member
3rd generation mason/construction here. I've forgotten more than I remember, but I (we) would never lay block or pour outdoor concrete in those conditions. Blankets would help, but looking at your 10 day forecast, I would make him wait until next week.
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Maybe you could put a coat on the mailbox and start a fire in a 55gal drum to keep it warm. Make sure that you send pics!
Oh Yeah ..... Nope!
I see you
FWIW I was going to pour a pillar for my astro mount a couple of weeks ago but night temps were in the 40's. I decided to wait for spring as the pillar needs to be very strong. Mortar between bricks in a non bearing construct wouldn't seem to need much strength but I'd wrap it in a blanket of some sort to prevent the water from freezing. YMMV
Si non potes inimicum tuum vincere, habeas eum amicum and ride a big blue trike. "'Bipartisan' usually means that a larger-than-usual deception is being carried out." |
Naw... |
OK, I think I will tell him to wait until after the "crazy cold" weather is past. It is not a urgent repair, but I don't want issues down the road.
Absolutely.
Driver
^^^ Tire warmers. We're car guys, right?
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Brick layer advice
As with everything else, it depends.
Cement does give off heat as it cures but it’s a function of mass and surface area. When I pour a 300 or 400 yard footing that is on the ground, in a hole and it’s 4 or 6 feet thick, we can throw blankets on top, draped down to ground and it will be fine well below freezing. If I do a 300-400 yard floor placement on metal deck, up on the building it’s only 3 to 6 inches thick, we have to enclose the floor where the work is taking place as well as the floor underneath and heat the floor underneath. I’ve been able to get 60 degree deck temperatures for those jobs even when the outside air temperature is at or below freezing. In the OPs example, you have a ribbon of mortar, 3/8” thick and 3” wide surrounded by bricks that are 2-1/4” thick and 3-5/8” wide acting as a heat sink. Sent from my iPhone using Tapatalk Last edited by wilnj; 12-21-2022 at 07:53 AM.. |
I called off the brick work to today. It is currently 26, and it will maybe be above freezing for a few hours, and the low tonight is forecast to be 3. Ain't no way I want anything with water in it outside in that. This is not some mission critical hard deadline project. I can wait until after Christmas when the temps will be above freezing at night.
Information Junky
Yeah, 26 - too damn cold to be working in.
Great time to go skiing.
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee.
