Ok…all pipes we can reach are now insulated. Will leave some taps open overnight to drip as well.
Keep the water running, slowly
Open cabinets under sinks (especially those on outside walls) so more heated air gets in.
In my vacation home< I use a small under sink pump system to return hot water down the cold-water line from the farthest point (from the water heater). It comes on when the hot water side cools to a specified level. It keeps both hot and cold lines from freezing. |
Run a bit of hot water now and then too...as water can freeze going out...as much as going in.
That is the Ice Age to many in the south. _ |
There are hose bibs that have the actual actuator inside the structure-these you just turn off, but disconnect anything connected or you'll defeat the purpose.
Even those can freeze if the cold gets deep enough into the wall.
There’s no excuse for having problems with hose bibs, failures are the results of bad architectural design and bad construction. |
THe big freeze that we had 2 years ago was because not only was there a freeze, but there were power outages too, so people didn't have heat in their homes to keep the homes and pipes warm. |
It is no fun freezing water pipes in an unheated ceiling. Many times you don't find out until after they thaw out and then you have a mess. See if you can get heat tape you can wrap around your pipe and cover the tape with insulation. If you can drain the waterpipes, try and blow them out and back flush them with RV antifreeze until the other end runs pink.
i keep a radiator type electric heater in my well house with a programable timer that starts it around 11PM and it runs till 7AM. Even though my pipes are sch 80 PVC and insulated sleep better with the heater on when the bitter cold shows.
the radiator type heaters are a very safe electric option compared to anything that glows red to heat. |
Fun fact.
The water is supercooled in the pipe and the pressure the pipe pushes on the water is what keeps it from freezing. Thicker pipe leads to the water being able to stay liquid at a lower temp under the freezing point. |
The red line is the temp. The thick horizontal blue line is 32º http://forums.pelicanparts.com/uploa...1671771344.jpg Quote:
Remember, hot water freezes faster than cold water.
2 degrees with the wind chill here in Houston this morning. Time to put away the flip flops.
http://forums.pelicanparts.com/uploa...1671804435.jpg |
15º outside, heat's still running, and the water is still flowing. This weather sucks!
https://m.media-amazon.com/images/I/..._AC_UY350_.jpg Granted, I'm inside and wearing long, thick wool socks with sheepskin slippers (wool on the inside), and a hoodie. I'm heating up breakfast, so put the air fryer (small one) on my desk with the exhaust pointing at me. LOL! The temp is trending up. 2º up, now 17º. The sun's coming up. We'll open the curtains in a bit to let a little of the sun's heat in. |
| All times are GMT -8. The time now is 06:03 PM. |
