I see you
flatbutt's Avatar
FWIW and I'm sure this is well documented somewhere but the energy density of propane v gasoline in this application may make a difference.
Old 12-24-2022, 06:17 AM
jyl jyl is online now
jyl's Avatar
https://motorsnorkel.com/propane-consumption-rate/
Here is some info on generator running time on propane.
Edit: looks like 1000 watts for 1 hour requires 20,000 Btu which is roughly 0.9 lb of propane.
So for my minimalist “just heat and net, ma’am” application, which I figure will require less than 1000 watts average, a 20 lb tank can potentially last most of a whole day. That assumes optimal generator choice - powering a 1000 watt load with a 14 kW genset is, I would guess, going to be far less efficient than with a 2 kW generator.
1 gal gasoline has 114,000 Btu, so a 5 gal can of gasoline can potentially last over a day, again assuming optimal genset choice. With multiple refuelings.
Old 12-24-2022, 06:24 AM
I see you
flatbutt's Avatar
IMHO you need to weigh how often you're going to need the gennie and how long you need to run it. Do you need it for water?Heat?Cooling?Food storage?
Sandy kept us on our own for 15 days. I was able to run my entire house on 4000W the whole time (water, heat, refrig, lights).
Old 12-24-2022, 06:57 AM
rfuerst911sc's Avatar
Depends on the house . We have a well pump so that's 220 . We have a dual fuel heat pump so again 220 . Our water heater is electric so again 220 . For us to have heat/AC and hot and cold water at a minimum I need a decent size generator for whole house. We have a refrigerator upstairs and a freezer downstairs.
In an emergency situation we don't need washer and dryer with the dryer being 220 electric . I " think " with modern soft start technology I could get away with a 10k generator with a 12k adding some insurance . That size is relatively affordable with decent fuel consumption. Most calculations say 17-20k is needed but I think that is maybe for a large family . It is just me and my wife .
Old 12-24-2022, 07:10 AM
jyl's Avatar
I’ll bet you were a popular guy! 15 days is a long time.
Here in urban PacNW, power outages are caused by windstorms, icestorms, and most often wind&icestorms, bringing down trees and powerlines/cablelines. The longest outage I’ve experienced in 16 years here - and only once - was power out for 4 days (internet out for a week). Most outages are only half a day or so, and those happen every other year or so. For a 3 day outage, I’d be fine with just being able to power heat (blower for gas furnace), internet, and spare me a hundred watts for laptop, phone charger, charging battery packs. Hot water would be nice (blower for gas water heater). Freezer isn’t that important to me (worst case, we and the neighbors all eat like kings for a couple weeks).
Old 12-24-2022, 07:32 AM
I see you
flatbutt's Avatar
I had so many 12 gauge extensions running out of my house it looked like the floor of a a server room.
The "Sandy-Q" in my neighborhood was epic.
Old 12-24-2022, 08:24 AM
It'll be legen-waitforit
stealthn's Avatar
Just watched a video on this yesterday: https://youtu.be/VdO32pDi4ko
Bob James
06 Cayman S - Money Penny
18 Macan GTS
Old 12-24-2022, 09:04 AM
After years of doing the back feeding thing we put in a transfer switch when we bought a Honda 7,000 120/240 inverter generator. I didn’t want to do the Generac etc permanent install because if we sell the house the generator goes with us.
I wanted an install that was electrically safer and something my wife was comfortable doing.
Recently we lost our power for 5 below-freezing days, it came back on and yesterday with the wild winds, one of our trees took all the power lines down.
The Honda runs our whole house; 220 well pump, 220 heat pump, 220 hybrid water heater etc. I did have to move some breakers around to balance the load so the generator wouldn’t alarm due to momentary overloads.
I went gas even though we have a 330 gal propane tank just because we can always get gas. Plus, being portable, gas power gives us the option to help others.
Our generator is installed in the garage with a proper exhaust pipe thimble as well as an exhaust fan with a powered air inlet damper. A CO monitor/alarm is plugged in.
It’s 14 degrees out now, my wife is watching her favorite show and life is good with over 100 hours in the past two weeks.
Welcome to “The Other” Maine.
Old 12-24-2022, 03:21 PM
^^^ Good info thanks for sharing .
Old 12-24-2022, 03:24 PM
When we had our eleven day outage last year people with 500 gallon propane tanks were burning through it running their generators. The propane companies could not get access to peoples tanks because of all the trees that went down. So , having a propane supplied generator was great until the propane ran out.
Old 12-25-2022, 07:57 AM
The down side of any generator is running out of the fuel source . If trees are down blocking access not much you can do . Being frugal by not running 24 hours a day can really stretch the tank. There is no perfect solution .
Old 12-25-2022, 09:00 AM
dlockhart's Avatar
My brother had one of these installed last year. Cheap ( relatively) and easy to install.
About 1k and less than 1/2hr .
He got great use out of it after a Dec 15 storm had him without power for almost 40hrs.
I'd get one but my utility co will not allow it in their meter. ( dumb)
So I'm left with the old skytrooper method.
Transfer Switch | Global Power Products
"The primary contribution of government to this world is to elicit, entrench, enable, and finally to codify the most destructive aspects of the human personality."
Jeffrey Tucker
Old 12-25-2022, 10:18 AM
wdfifteen's Avatar
Would the best (easiest, cheap, but safe) way be to run a subpanel with transfer switch, wire that key stuff to the subpanel, and power just that subpanel from the generator?
That's the way mine is wired. We just power the kitchen lights and outlets, water heater, furnaces, and a few lights. We were out of power for a while Thursday night and it worked well.
Old 12-25-2022, 10:23 AM
jyl's Avatar
I thought of something. When we replaced our gas clothes dryer with an electric one (bad decision), I was left with an unused nat gas line in the basement. I could extend that line to a hookup on the outside of the house, on the other side of the wall from the dryer location. Then install a propane/nat gas kit on whatever portable generator I get, and voila no worries about running out of fuel, assuming gas is on.
Old 12-25-2022, 10:24 PM
In your scenario I would add a tee at the dryer junction with a shutoff and then extend the line for a generator . That way if you want to go back to a gas dryer it's easy to do .
Old 12-26-2022, 06:24 AM
Been here a while
I think you will find that the line sized for the dryer isn't sufficient to run a generator.
looking for 1972 911t motor XR584, S/N 6121622
Old 12-26-2022, 07:24 AM
jyl's Avatar
Ah, thank you.
Old 12-26-2022, 09:55 AM
jyl's Avatar
Link stashed here for reference
Natural Gas Generator Pipe Size Chart
I need to start measuring :-)
Old 12-26-2022, 10:13 AM
fancytown
I can't find the exact outlet, but use an outdoor version of this through the basement foundation wall.
It connects to a duplex outlet near my furnace that are only energized by this plug when a generator is running. Then an extension cord up the stairs to the fridge and whatever else. Saves keeping windows cracked open to run a cord. Also less extension cord length. It's basically a hardwired extension cord that carries no power unless you plug in a cord from you generator.
Also, your truck tow hooks are useful for securing your generator.
Old 12-26-2022, 06:45 PM
