-   -   What oil should I use? (http://forums.pelicanparts.com/off-topic-discussions/1132433-what-oil-should-i-use.html)
WPOZZZ 01-04-2023 03:06 PM
Can't choose the oil to use when making stir fry. I like sesame oil or chili oil, but wha about olive, grapeseed, avocado or coconut oils?
pwd72s 01-04-2023 03:07 PM
Which one works best for scraping stir fried kale out of the pan and into the trash can?
stevej37 01-04-2023 03:08 PM
Don't know about stir fry...but I use coconut oil every morning for hash browns.
The taste is better than any other oil..imo
Here...it comes solid in a plastic container.
Bill Douglas 01-04-2023 03:11 PM
20W-50
Sorry, wrong thread.
I use rice bran oil for anything that gets very hot like a stir fry. It doesn't burn.
flatbutt 01-04-2023 03:19 PM
I know for certain that olive oil is not good for stir frying as the high heat damages most of its' healthy bits.
In general the oil with the higher smoke point is better for stir frying.
https://www.optimizenutrition.ca/blog/healthiest-cooking-oil-comparison-chart-with-smoke-points-and-omega-3-fatty-acid-ratios/#:~:text=Healthiest%20Cooking%20Oil%20Comparison%2 0Chart%20with%20Smoke%20Points,%20%2083%3A1%20%202 8%20more%20rows%20
berettafan 01-04-2023 03:26 PM
well it won't be good fried rice or stir fry without at least SOME sesame oil. I would normally start with canola oil and add sesame in part way for flavor.
Bill Douglas 01-04-2023 04:17 PM
I learnt a new trick on Christmas day. A friend was cooking abalone fritters and put rice bran oil in the pan. Got it pretty hot then added butter. He said the rice bran stops the butter from burning.
Abalone fritters were good!
masraum 01-04-2023 04:20 PM
LOL! I've seen that meme, hilarious.
Coconut oil is good, but does impart a flavor, and I'm not sure that flavor is good for everything.
Yes, and no. I agree that most (99%) of olive oil (mostly EVOO) is bad for high heat applications, because the heat adversely affects something in the oil and actually makes it bad for you. I have read that you can get "light" meaning light colored which is heavily filtered and refined olive oil that is fine for high heat applications. But the missus and I have looked for it in the past, and it's not easy to find.
Exactly, sesame is, IMO, more about adding flavor than using in bulk, but a little (not sure if added at the beginning or end) would be good in a stir fry.
I think for stir fry, I'd stick with something high heat, and if possible, something that is commonly used in Asia for stir fry. I think that's often peanut oil, soybean oil, and vegetable oil. I think that grape seed which has a high smoke point would also be good. Personally I'd probably go with peanut or grape seed.
stevej37 01-04-2023 04:20 PM
Where do you get rice bran oil?
Never seen it here.
Bill Douglas 01-04-2023 05:02 PM
Never seen it here.
Oh, I just get it at the supermarket. Alfa One brand.
Here it is https://www.amazon.com/Alfa-One-Rice-Bran-Oil/dp/B00BHFE8KK
asphaltgambler 01-04-2023 05:24 PM
Peanut oil, add a little sesame oil for flavor.
flatbutt 01-04-2023 05:43 PM
Man you must need to squeeze A LOT of rice bran to get oil out of it.
flatbutt 01-04-2023 05:45 PM
There is a low acid version that's ok for high heat cooking. I rarely use high heat for cooking so EVO usually suffices for me.
Shaun @ Tru6 01-04-2023 05:46 PM
Both grapeseed and peanut oils have very smoke points. Grapeseed is the most neutral of all oils.
I also use tallow, pure beef fat. I got some lard once and it was bad and haven't been able to go back.
Just made some chili oil tonight, for drizzling and dipping.
http://forums.pelicanparts.com/uploa...1672883058.jpg
Gogar 01-04-2023 05:47 PM
YES this. Peanut oil hot as hell, sesame is only for taste at the end.
cstreit 01-04-2023 06:10 PM
Avocado oil I think has the highest smoke point? I use it to season my cast iron.
No flavor at all that I can tell.
Bill Douglas 01-04-2023 06:20 PM
Yep. Must be a lot of people in China squeezing rice all day.
masraum 01-04-2023 07:48 PM
I was thinking that was the case for Avo oil, and I've seen it in a store, but I haven't ever used it.
That does seem to be the case.
https://en.wikipedia.org/wiki/Template:Smoke_point_of_cooking_oils
juanbenae 01-04-2023 08:15 PM
i look to oils that don't burn the pee slit.
cstreit 01-04-2023 09:13 PM
Lol You are so wrong dude.
