Get a snowmobile
1980 911 - Metzger 3.6L 2016 Cayman S |
Senior Member
Leland Pate! Perhaps my all time favorite Pelicanhead.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Senior Member
I felt a great disturbance in the force this morning and thought I'd check in on the PP OTD since it's a slow day at work.
...that, and I needed to make sure Jim was still kicking... ![]()
-- Chief Architect and Mastermind, SCWDP |
That said, at the same time during this experiment, I remembered I need to be in a much better shape to endure an entire day of skiing and get my $200 day pass worth, so it's academic... Skiing has gotten too expensive for my tastes - kids with a lesson and rental were $300 per day each, come on.... |
Wildman Emeritus
I have found that the best deal is a season pass. One for the U.P. & one for all the Vail properties. For about a grand(5 days at walk up prices) I get a lot of days on the slopes.
Pricing for day tickets is stupid high. Don't know how families afford it, plus equipment, food & lodging. And the industry is wondering how to get more people involved?
Mike Andrew 1980 SCWDP 2024 Suby Forester 2018 BMW X1- Wife's 2000 Boxter - Sold |
The best new ski equipment is a helmet, so much more comfortable than a hat, and useful too. I have not been out skiing for about 10 years, so quite outdated, only thing I can recommend if looking for new ski's is consider an all mountain ski vs dedicated type, I have a pair of Atomic Beta race 9.16 and a pair of older Rossignol GS ski's, both are great at what they are intended to do but lack everywhere else, I have rented a couple pair of all mountain years ago and really liked them.
87 930, |
Flat Six
Equipment in the '70s, '80s, through the mid-'90s required a highly dynamic sequence of pressuring the forefoot to engage the ski tip, setting and driving the inside edge of the downhill ski, and -- especially for bump/slalom skiing -- intentionally loading and unloading the tail. Lather, rinse, repeat for each turn. That's why boots of that era (and even a little later) had so much 'ramp angle' built into sole and forward lean in the cuff; "shin bang" was often a badge of honor. The need to intentionally drive skis of the day also necessitated a fairly stiff boot. Try using boots w/the older geometry on modern skis and you're begging to have a miserable day.
Modern skiing (last 12-15 years or so) is based on a more upright and centered fore-aft balanced stance. This is way easier on the hips, knees, and ankles, as well as the lower back (not an insignificant concern for someone my age). Boots are designed with this geometry in mind, and so are modern skis. Modern all-mountain skis are shorter, wider, and -- frankly -- far more versatile than anything built pre-2005 or so. Yes, they're easier to turn than 'straight' skis I grew up on. And easier to ski in light snow (or wet & heavy new snow -- 'creamed corn' -- you're likely to see at Hood). They'll carve like crazy on groomers and as long as you have a reasonably recent tune on them, will hold really well on Cascade Concrete or Sierra Cement (hardpack to the rest of y'all). And yes, a decent mid-level ski can be stable at cruising speeds far higher than I'm now comfortable with, as (or more) stable than the 205 Atomic GS I skied in my 30s. Try to ski them using boots & technique from the '70s/'80s/early '90s, though, and they'll feel super squirrely. +1000 for a helmet; been using one since the '90s. Felt like a super-dork the first time (this was back when very few people wore one) but I was hooked on the warmth, especially for my ears. And a good boot fitter can work wonders, even for the bunion-afflicted. With modern moldable shells, custom-molded liners, etc. there isn't much a good fitter can't accommodate. This is my 46th ski season; I fit boots and sold skis at Fiorini Sports in Seattle for a decade. Happy to answer anything I can for anyone who's interested.
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
[QUOTE=Flat Six;11889236]
And a good boot fitter can work wonders, even for the bunion-afflicted. With modern moldable shells, custom-molded liners, etc. there isn't much a good fitter can't accommodate. Bunion affected here. What do they do to boots to make them open in that area? If I wear a modern regular ski boot for a day....I suffer for 3 days or more after.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Information Junky
Wow, Flat Six, what a great post.
I still ski my old slalom skis from the 80's, (710-FO) and ski them exactly as described above. - Lang-bang is a feature. ![]() Newer skis have massive side-cuts (great) but don't have the tip-to-tail progressing stiffness, that 'bounces' me out of the turn, nor does the "cap-ski" manufacturing process lend itself to high torsional stiffness. :-/ Seems that if I want anything close to my old, beat-up gear I need to find some racing skis. Any suggestions?
Everyone you meet knows something you don't. - - - and a whole bunch of crap that is wrong. Disclaimer: the above was 2¢ worth. More information is available as my professional opinion, which is provided for an exorbitant fee. ![]() |
Used to Ski, now I Snowboard, a helmet is the new addition for those icy place skis work better on.
Flat Six
[QUOTE=stevej37;11889259]
![]() We'd then work on the liner, typically using a combination of compressing the foam liner where it met the head of the protrusion and adding foam around the bunion area, allowing for any pressure to be more evenly distributed around that area of the foot. There are several current boot models that use custom-molded shells -- essentially your fitter will heat up the shell, you put your foot in it (w/the liner and your footbed inserted), and buckle you up. Fischer boots (ones I'm most familiar with) then essentially apply a vacuum to the whole boot to mold it to your foot/ankle/heel/instep etc. Once it cools, done deal. Here's a decent overview of boots with custom-moldable shells currently available: https://patriotfootbeds.com/blogs/news/122776711-ski-boots-with-heat-moldable-plastic-shells Most skiers, though, don't really need custom-molded shells; a good fitter can punch or grind a small spot or two and work wonders. Everyone, IMHO, needs some kind of customized footbed, and most folks would benefit from custom-molded liners. None of this is cheap, especially compared to when I started skiing (but then again, what is?). When lift tickets are $150+ the price of good-fitting boots makes a lot more sense.
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport Last edited by Flat Six; 01-05-2023 at 02:39 PM.. |
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Thanks Flat Six for that info.
My bunions, esp the right foot, are severe. Plus I'm 70 years old. I have a local ski shop in Grand Rapids that I might stop into and check out some boots. The Salomans (sp) that I have now won't work. I used to just fly out to CO and rent ski's and boots. That day may be done. I guess it wouldn't be that much more trouble to bring boots with me.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI Last edited by stevej37; 01-05-2023 at 01:54 PM.. |
GaryL
Ski Boots age over time due to UV exposure and other environmental conditions. The plastic will stiffen and become brittle.
Ski bindings have come a long way and lower leg injuries have been greatly reduced over the last 20-30 years. Ski shops will not even adjust older bindings due to liability issues. For skis I went from 195's to 174's and never looked back. So much easier on the legs and stable at higher speeds. For those that remember Hanson boots they were really not for expert skiers but were quite comfy. The company went out of business in the early 1980's. Fast forward 40 years Denny Hanson who started Hanson boots is at it again with Apex Boots. It is essentially a snowboard boot that is wrapped with a stiff removable outer shell. I bought a pair and used them only once so far this year, but they are super comfortable, easy to get into and out of and warm. And they perform on the steep stuff really well. (I am a 50-year ski patrol member). Being older these boots are a game changer for me. Without the shell they are easy to walk in and go up and down stairs. |
Flat Six
The first cap skis typically used a foam or solid wood core, with a molded fiberglass cap of relatively coarse weave (or even strand) adhered on top; the cap was a structural element of the ski and really didn't sacrifice much in the way of torsional rigidity especially in the low- to mid-level skis this design was used to produce. The problem was that as ski designs moved to shorter lengths with wider underfoot widths and huge sidecut (remember the Elan SCX? Looked like a pair of soup spoons welded handle-to-handle) structural cap designs didn't really work. Volant Skis out of Colorado(?) tried to solve this issue by using a stainless steel cap, and were one of the best-selling brands for a few years of that era. But other companies made cap skis with very high torsional stiffness. 908/930 mentioned owning Atomic's Beta 9.16; that was a cap ski that nobody would question the stiffness of. Modern skis don't have nearly the sidecut/hourglass shape that late '90s skis did so concerns about sufficient torsional stiffness aren't nearly as important as before. Most use some flavor of laminate construction, some with composite layers/wraps/sections using glass, graphite, and kevlar in much finer filaments than before. Modern skis also have more rocker than your 710s ![]() ![]() If your skiing style is more 'traditional' I'd look first to what I call the 'Germanic-heritage' brands like Atomic, Stockli, Volkl, etc. Their historical design DNA is to deliver stout, energetic, beefy-feeling skis. Not that other manufacturers won't have models that are as lively as you'd like, but IMHO you're more likely to find what you're looking for there. I'd encourage you to give something new a try; rather than doing a regular rental try a 'performance demo' instead. Assuming you get a good recommendation from your ski shop I think could be pleasantly surprised. One side note: I think modern skis, because of their width and the interplay between their sidecut (curvature when looking down on the ski), rocker (curvature when looking at the side of the ski), and longitudinal stiffness makes them more likely to ski crappy when their bases and edges have been neglected. Used to be you could maybe ski 40-50 days on straight/skinny skis without getting them tuned, just touch up edges and wax them. Personally I wouldn't ski a modern ski more than 15-20 days without a fresh tune. I'm not nearly the skier I used to be, but I can still feel the difference. Oh, and adding a beefier power/booster strap to the top of your boot cuffs will help reduce your Lange Bang! ![]() ![]() Just my $.02.
I too, was a long board skier. Loved my 205 & 207 GS cut Rossis. Skied many many days on them.
I bought some lightly used Volkl Mantra's a year or two ago. Oh my. I have had early shaped skis but these are the BOMB. Rather than suggesting what to buy, I will suggest that you (whomever is reading and cares) demo skis. My buddy has some very highly thought of skis that I considered buying. They were #2 on my list. I swapped skis for a few runs and they did nothing for me. Him either. He wants my skis! Another thing. I have pretty nasty sural nerve issues on my left leg. I was getting nerve tested for some other stuff and the Dr. announced it. She tells me that it is from ski boots. When I read about Lange Bang (yes, I skied the orange boots for YEARS), I think about my sadly damaged nerve... Ouch. That sucker HURTS. I do find a hard plastic roller helps significantly. A note. And, as a parting shot, I will share my vision. A few years back. Mrs. LWJ took me to Whistler for a ski weekend. It was great. But what was really great is that Whistler had more 80+ year old dudes skiing than I have ever seen. I was inspired. Skiing last night in softer, cut up snow really wasn't demanding. No hard jarring. No impacts. Nothing but gentle feedback from my turns. Which, is something I expect to be able to do for a few decades. Last edited by LWJ; 01-05-2023 at 02:31 PM.. |
Flat Six
One thing that may help when transitioning from what I'll call 'traditional' straight skis to modern skis (we'll skip the overly hourglassed 'shaped' skis of the '90s) is that a more upright and balanced stance allows for much greater use of both uphill edges when carving and turning. When I learned to ski it was pretty common to weight the uphill edge of the downhill ski roughly 75-80%, more on steeper slopes. Weight on the uphill ski was primarily just for balance. Now I feel its more like 60-70% and you (ideally) actively use the uphill edge of the uphill ski to turn & carve. Old dog, new tricks.
Flat Six
In the context of carting along ski clothes, gloves, goggles, helmet, etc., traveling with boots is no big deal. My skis are so much shorter now, they're not an issue either, really. Oh, and for anyone who skis and doesn't have one yet, get yourself a heated boot bag. Keeps the shells warm and pliable, making them -- I kid you not -- orders of magnitude easier to put on. Plus you put your feet into toasty warm boots and IME makes for a way more comfortable and enjoyable day. Plug into the wall and warm them up overnight, 12V cigarette plug keeps them warm on the way up the hill. Best skiing-related purchase I've made in the last 10 years.
Flat Six
Great advice. Remember that most shops (both local and on-hill) will apply your rental/demo fees toward your purchase of a new pair. If you can't demo a ski before you buy, understand very clearly the seller's return/exchange policy before you part with your $$$$$.
Thread Tools | |
Rate This Thread | |
