Dry Ice Blasters
Does anyone own one and can recommend a unit and an air compressor to power it?
There are a handful of sub $7k units that might be worth the investment and I’m doing some prelim research thanks. |
Misunderstood User
Cool Clean technologies. We use dry ice blasting to clean molds from injection presses.
Jim 1983 944n/a 2003 Mercedes CLK 500 - totaled. Sanwiched on the Kennedy Expressway |
My shop partner bought one, I’ll ask him. I know it takes a hell of an air compressor to run it.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
canna change law physics
I have a patent in this area. Can't help you on the devices.
James The pessimist complains about the wind; the optimist expects it to change; the engineer adjusts the sails.- William Arthur Ward (1921-1994) Red-beard for President, 2020 |
^^^^ explain....
Give us some details....
Turn3 Autosport- Full Service and Race Prep www.turn3autosport.com 997 S 4.0, Cayman S 3.8, Cayenne Turbo, Macan Turbo, 69 911, Mini R53 JCW , RADICAL SR3 |
Thats another issue to figure out thanks
1980 911SC Targa 3.6L |
I have a ColdJet Aero 75. Runs at a minimum ~200 CFM = 400 gallon compressor for non continuous use however there are smaller ones out there. Your hard lines from your compressor need to be bigger than what you have. If you don't have a ice supplier close to you look at other options such as steam. Ice has a short shelf life. Works well for cleaning most car/industrial stuff. It will damage wire insulation if you're not careful. My $0.02
'87 911 GP White "casper" '79 930 Copper Brown Metallic "beast" '93 968 Amazon Green Met "moby" '97 Esprit V8 "flat eric" '97 993 Speed Yellow "tbd" |
