Counterclockwise?
Even though Canada is metric we have industries that stick with imperial because of the costs and efforts for retooling.
I'm in the printing industry and everything is imperial. Another is the lumber industry.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
In New Zealand we have been metric since I was a little kid. But certain things are still in imperial. Such as "He was a six feet tall guy." If you said "He was a 1.83 meter tall guy." No one would have any idea what you are talking about.
"How was the surf?" "It was huge, I had to take my 6'10" out." Metric is sure great when doing building. "A bit of wood cut to 1.265m thanks" |
My 1986 El Camino is a confusing mix of metric and SAE. The engine is SAE for the most part. The chassis is mostly metric. There are times like removing the accessories like the AC compressor, I have to use SAE and metric too get all the bolts off, and it is the only time I ever need to use a 16 or a 18 mm socket. The Power steering high pressure side requires a 18mm crow foot line wrench. Try finding that at a local store. I had to chase down a Snap On truck to get one.
The world uses inch size wheel, 15, 16, 17 inch and on up. The entire world uses the same size of SAE seat belt anchor bolt as it is specified by the US DOT. Virtually all the world uses the same size valve stem threads for tires and the caps.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Banned
we have gone metric. at least the entire technical world has.
You do not have permissi
Base-10 is easier to convert than Base-16. The nomenclature is still very bad.... Meter whut? Are we talking astronomic or microbiology????? There is no distinction between "big" and "small", relative to basic human thinking. Do they drill this conversion shyte into every student in every school? Simple answer. Quote:
Biting the hand. There was a small argument...probably fake..that the Earth's atmosphere would not be conducive to penetrating it. And going into the layers of 'space' surrounding the Earth would be fatal due to radiation or other factors. (Especially with 1960s tech.)
Meanwhile other things are still happening. |
For the record: I could not edit this last post.
-PP hit me with a popup "Not https. blah blah. Third parties could see". WTF. Never saw that before. My browser should block these. (but PP is on the trusted exception list i think) -And then an "entry is too short" error. Fatal error. So basically editing and submitting any further user information from this node was blocked. Two fatal error messages with only one post. I never saw this before. 20 years on Pelican Parts.
Meanwhile other things are still happening. Last edited by john70t; 01-26-2023 at 11:17 AM.. |
Look into garage tool chests...pretty easy to spot the one owned by an old guy...it will have both SAE and metric tools. The young guy will be metric..
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
LOL! Cindy bought a Canandian made propane BBQ I had to assemble...sure glad I had that crazy tip among my 1/4" hex bits...Damn...now remembering the hassles. Terrible set of assembly instructions. Lots of cussing on that one.
Home of the Whopper
Who created the metric system?
What defines a meter?
“The wave is not the water. The water merely told us about the wave moving by” – Buckminster Fuller |
Banned
one of my favorite tucker carlson's: https://www.youtube.com/watch?v=1cPeZLCVWTw
its very funny to me because of course, all imperial units are actually defined by the metric units now. Last edited by cockerpunk; 01-26-2023 at 12:28 PM.. |
Counterclockwise?
That's all of us old farts on PP!
Home of the Whopper
That was funny.
Hope it wasn't supposed to be serious!
Immature Member
Tires/wheels are an interesting mish mash of both….. 265/50/R 18 (265mm section width on 18” wheels). No idea why. 🤷*♂️
1983 AUDI Turbo Ur quattro 1987 PORSCHE 944 turbo |
If my memory from childhood is any good, I think they took a good run at teaching the metric system to us grade schoolers- I think it might have been a Jimmy Carter deal? I was probably in third grade, so don’t trust my recollection!
I use both, but splitting small measurements in half is easier in imperial.
Rutager West 1977 911S Targa Chocolate Brown |
At some point back in the 1980's the Fed DOT tried to get all the state DOT's to change all the highway signs to the metric system. NY as I recall started but the whole thing landed with a thud. Those signs quickly disappeared when the idea died from too much public resistance and pointless cost.
In engineering school in the early 80s we had to deal with both systems simultaneously
They'd give us an exam and one problem would be metric, the next would be Imperial, etc. What a PITA that was.
This is 'merica, we can use whatever we want including mixing them up for no reason at all
Gonna fill my tires with 1e23 k Newton/(Mile)^2 and let the eagles soar
84 930 18 Cayman GTS |
Insert Tag Line HERE.....
i certainly dont need/want to learn a whole measuring system at this point in my life!
Marc |
