Fleabit peanut monkey
Bob Kontak's Avatar
Oil filter removers - is there a system?
I'm talking about the round caps that you use a 3/8" ratchet or extension to remove the filter.
Is there references on the filter and the caps that would allow me to know which ones mate?
I hope this ends up being a stupid question and there is a system because I just chuck them all in a tub and dig for one that fits.
1981 911SC Targa
Old 02-04-2023, 01:51 PM
I use the 3 jaw style it clamps down as you turn it. Pretty much always works
Old 02-04-2023, 01:58 PM
astrochex's Avatar
I like your current system.
Paul
06 MINI Cooper S - 19 yrs of fun (sold)
2011 Cayman (she purrs, loudly)
weekend wOrrier
How big is your tub/ bucket?
Old 02-04-2023, 02:03 PM
After the one pictured in the OP, then a strap wrench, then a screw driver through the filter (messy), I use "Big AZZ" Channel locks ..... that's my systen
True story for the first time I removed the filter on my 911 btw. Ever since I just use the first one....
I see you
flatbutt's Avatar
BACls every time.
Old 02-04-2023, 02:05 PM
weekend wOrrier
BACls every time.
I find positioning myself directly under the filter gives the best leverage.
Old 02-04-2023, 02:07 PM
$10 strap wrench
Bob Kontak's Avatar
I probably have 15 of them but I don't think that's even close to the number of sizes available.
1981 911SC Targa
Old 02-04-2023, 02:09 PM
weekend wOrrier
15?!?!?
That deserves a redneck sheet of plywood with long screws in it on the wall (or somewhere) with the filters arranged from big to small or something. You can't be fishin' through 15 filters like that!
(edit- I use a strap wrench myself, with the correct open end wrench sitting right next to it.)
Old 02-04-2023, 02:13 PM
For my El Camino I have one kinda like the one in the first post.
For the Porsche, that same adapter would work, only if I had the space by removing the air filter. So I just use a strap wrench to get it loose, and then my fingers. I just tighten it down with my hands.
Oil filters are every size possible so no standard except large Channel locks, or strap wrenches. No way to get a strap wrench on some like my El Camino. Just the end socket.
Old 02-04-2023, 02:15 PM
Everyone needs "Big Azz" Channel locks just because that's stamped on them ... I LOL'd when I saw them .... a must have
Old 02-04-2023, 02:17 PM
weekend wOrrier
Here's what you want. "It's what every white boy off the lake wants"
Make a delivery system similar to a beer flight board which you can carry right under the car and start trying filter tools. Too small- reach over and grab a larger one...or vice versa etc....
When you know what car a filter works on, write it on the board.
But you don't want four boards, only one, with handles, that holds all 15 and the wrench, like a TV dinner tray.
Old 02-04-2023, 02:44 PM
+ 1 for Chanel Locks.
Old 02-04-2023, 02:49 PM
KNS KNS is online now
I have one of these and and it will defeat anything. Channel Locks are great but if you look at the small oil filter on the 993 access is really tight. The three claw job can get into that tight space.
Kurt
Old 02-04-2023, 03:09 PM
Until the rubber ends disappear. Then they no work.
Old 02-04-2023, 05:43 PM
Bill Douglas's Avatar
I had, well... have, one of these. It's currently stuck on the Corolla's oil filter. It's on but spinning around and I can't get it or the filter off.
I've bought a better on made of moulded aluminium, whereas the stuck one is pressed steel, but I have to get it off first.
Luckily the SC has excellent access to the oi filter and I have a remover that looks like a handle with a length of bicycle chain that wraps around it and tightens as you turn it. Works well.
Old 02-04-2023, 05:51 PM
Driver
Noah930's Avatar
LOL.
I've used answer E: All of the above.
I think I have acquired about 8 or 9 different wrenches/ratchets/3-prong thingies over the years. And then, sometimes vampire-style (screwdriver through the filter) is the way to go.
1990 Black 964 C2 Targa
Old 02-04-2023, 07:17 PM
pwd72s's Avatar
2 cup thingies, 2 sizes of steel band wrenches, a pair of oil filter pliers, AND a set of big ass 18" Craftsperson chan-l-locks...all in my rollaway.
And today? To the dealerships, write a check, drive home.
Old 02-04-2023, 08:17 PM
Driver
Noah930's Avatar
Anyone else like the little moulded in "nut" at the end of K&N filters because of this?
Old 02-04-2023, 11:09 PM
