Platinum Member
Close-up electrical work magnifier?
Damn eyes don't work like they used to. I can usually get by with reading glasses, a few years ago I started using magnifying visor from Amazon (I think someone here recommended it?)
I am without at this location, and today used my iPhone screen/camera mounted a few inches above the circuit board I was soldering. Worked in a pinch. Is anyone using digital magnification for close up-work? Will I get used to looking at a screen instead of the actual work? I was thinking something like this, $100 at Amazon:
Political polls are often to give you an opinion, not to find out what your opinion is - Scott Adams |
Evil Genius
Life is a big ocean to swim in. Wag more, bark less.
We bought my MIL this and she loves it:
https://daylight24.com/shop/ I don't know if this will work for your purposes, but she sews, quilts and does a lot of puzzles.
1996 FJ80. |
Senior Member
I agree with Rusty. Again.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
For circuit board/electric work - this looks like it might be better suited, although the clamps holding the board in mid-air do make me question if that is an ideal method.
https://amscope.com/products/c-magled-42?utm_source=affiliate&utm_medium=rakuten&utm_campaign=rakuten&ranMID=43027&ranEAID=JNLJ1ZP2xGI&ranSiteID=JNLJ1ZP2xGI-ANF41cP5pdZLaOY1JXT37Q
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
My readers are normally 1.25. When working on soldering projects or small gun internals, I use 2.75 readers and they make a huge difference.
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Using a direct magnifying product, be it on your head, or a large magnifying lens and lots of light is the easiest.
I think you will have to learn from scratch how to solder or to do anything but inspect with a remote display and a magnifying lens. It is a real challenge to try to manipulate something that you are not directly looking at. My brain wants to see whet I am doing directly. Doing it while looking at a magnifying camera display is just something most people don't just do naturally. For just inspection, a camera and a remote display is great. ![]() This is just right from my iPhone 11 Pro with no special attachments or lighting. It is the smaller relay for the footweel blowers on my 85 911. The coil behind the relay produces a magnetic field only if the fan in the engine compartment is running, and the makes a reed switch close and energize the little relay and turn on the footwell blowers. Only German engineers could think up such an elaborate Rube Goldberg like circuit to operate the heater. I need to find those reed switches and the coil to try to repair my old blower relay.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Platinum Member
Just passed a vision test on a DL change, so I guess my vision must be fine.
Counterclockwise?
I just put 2 sets of readers on. Works well.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs |
Same problem here, I am considering a set of $40 Dental Binocular Loupes, at the moment I use a magnifying headset with readers but need to keep close to work, not good when soldering, the binocular loupes have a focal point of about 16" away.
87 930, |
Kind of on the same subject, but when I’m welding, I need to get close to see what’s going on. I use my prescription glasses but is there’s something to magnify what I’m seeing, so I don’t have to get so close?
I really could’ve used it when I was on my back and welding the front sway bar supports on the 330. |
drew1 wife has 924 turbo |
R&D guy
Location: the border between the states of inebriation & confusion
We used quite a few digital magnifiers for electronics and precision assembly at work, but I always found it difficult to look up at a monitor rather than looking directly at the objects being worked on.
While an illuminated magnifying lamp (like the one shown by "Superman" above) is good, my preference is to use a simple head magnifier (sometimes with an extra lens) for fine work, and for extra-fine work, like my work on watches, I use a inexpensive binocular microscope. ![]()
Thanks!
