Author of "101 Projects"
Need some help...
Hi all. As many of you know, I'm working on the restoration of this car here:
Adams Probe 16 Restoration Project... There is a custom motor mount which uses some type of suspension bushing, but I cannot seem to locate a replacement. Most bushings are listed as fitting a particular make/model/year of car, but the websites don't ever seem to list the dimensions? I found a Urethane bushing that will fit, but I want to use rubber, since this is being used as a motor mount, and it needs to have maximum vibration dampening. I've spend about three hours trying to track this down now, and such a simple task seems to have left me flummoxed. Any suggestions? Here's the bushing: ![]() Here are the dimensions: ![]() Here's the generic bushing that will fit, but made of urethane: https://www.energysuspensionparts.com/9.8141 Any suggestions? It might be off of an Austin MINI or a Jaguar from 1969 or so. Dunno... -Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Gallatin, Tennessee
Found this site. Have to convert to metric but it may help.
https://superpro.com.au/bush-sizing Dave |
If you come up empty, I have a tip.
I met a guy who rebuilt a 1920’s Marmon (I think!) engine. He needed piston rings. Naturally nobody had them. He went to a NAPA and they had books and books of piston rings. He went through until he found a size that fit. I saw the car running, so it worked well. This happened 20 years ago. Not sure if they still have these magical books or not. It’s possible. Good luck! |
Hard rubber will turn on a lathe. May have to use a Dremel type cutter on a grinder post. The inner bushing can serve as the mandrel.
^^^ might turn better if good and cold - dry ice?
Several options here:
The countermen at my NAPA store would look through their stock for me to find a bushing that fit. I know that isn't the case everywhere, but that would be my first option. The other option is if you can't find a bushing to fit that piece of pipe, find a pipe that fits an available bushing. Cut off the old pipe and weld on the new one.
-Wayne
O'Riley's, Autozone, etc can't find their own asses without a model make and year.
Actually, I looked at the chart, matched the best one, searched the Internet, came up with eBay Australia, and that part number says it matches a Ford Capri 1974 1.6 Coupe. So that might prove to be very useful! -Wayne
Control Group
One of our members makes rubber parts, 914 guy from Canada, can't recall his screen name, Bruce is his actual name I think
She was the kindest person I ever met |
With a spinning cutter at 20,000 RPM (it doesn't matter how fast the lathe is turning) chances of snagging the part are minimum. Feed rate is also key. And it makes a hell of a mess.
I have the lathe and the Dremel. No way to hold it. The best set up is a Dumore grinder but I don't have that. Here is a cobbed together die grinder on a tool post. ![]() One can use a stone or a bit. A stone would finish it up nicely but it won't plunge to make the initial bore. |
Rubber shock absorber bushing maybe ?
Might take a look at this one:
https://www.steelerubber.com/shock-and-stabilizer-bushing-50-0220-32
74 Targa 3.0, 89 Carrera, 04 Cayenne Turbo http://www.pelicanparts.com/gallery/fintstone/ "The problem with socialism is that you eventually run out of other people's money" Some are born free. Some have freedom thrust upon them. Others simply surrender |
I've been thinking about this problem all morning and came up with a nerdy solution of sorts.
Take the urethane bushing and drill a series of holes parallel to the main hole in the wall of the bushing. Holes about .040 in diameter should leave enough wall thickness to give it some rigidity but also give it some flex. I'm sure Wayne has the smarts to figure out how many holes are needed to give the desired cushion for the mount. I'd think the urethane would last a lot longer than any rubber part.
Scott '78 SC mit Sportomatic - Sold |
Here is one that is pretty close:
https://www.summitracing.com/parts/paj-1203-r
This thread is an example of Pelican Awesomeness.
Bunch of engineers/ DIY people solving problems. This is simply good clean fun. |
We would freeze our bushings with either dry ice or liquid nitrogen then cut our bushings to size
It looks rather like a TR6 trailing arm bushing.
I’ll go measure one tomorrow and check dimensions. |
Any luck with this?
Guys on the w140 board on Benzworld turn down BMW bushings to fit MB control arms all of the time. Me, I just bought complete arms, but its doeable.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
