Wheel offset
I have 17” rims that are 50 and 55 offset. Am I stuck getting those offsets or can I get others. I can’t find any my size that are not the rims I am trying to get rid of.
Thanks.
Old 06-04-2023, 06:06 AM
The wheels I am looking at are 43’s.
Old 06-04-2023, 06:16 AM
Still Doin Time
asphaltgambler's Avatar
We need a lot more information. What vehicle, what is the current setup, etc, etc
Old 06-04-2023, 07:07 AM
Driver
Noah930's Avatar
Are those wheels stock/OEM sizing? You can always get wheels with an even higher offset and use spacers to make them fit.
1990 Black 964 C2 Targa
Old 06-04-2023, 08:52 AM
As stated, it's going to depend heavily on the vehicle.
The offset could impact if you get fender rubbing or rubbing on the suspension. You could have tons of space to change the offset without any impact at all or you may have very little wiggle room. You may be able to change the offset and then compensate as asphalt gambler said. Or maybe you want the wheels to stand out a bit more to be closer to flush or even stick out of the fenders a bit.
Depending upon the vehicle, you may be able to find folks that have strayed from stock sizes to get more info without needing to perform trial and error.
Old 06-04-2023, 09:50 AM
1999 Boxster. I just found out I have to consider bolt pattern too. I want to stay with 17”’s. I just prefer the look.
Old 06-04-2023, 11:31 AM
The Unsettler
stomachmonkey's Avatar
Well thats always been part of the problem. 130mm is not a common pattern but all Porsches (except Macan) use it. There are AFAIK 16 automotive brands that have used it but for only 1 or 2 models in their line.
Because it's uncommon there are not a ton of aftermarket options, the demand is not really there.
The only other brand that I know of who standardizes on it is SsangYong, South Korean automaker who makes SUVs and cross overs exclusively.
"I want my two dollars"
"Brandon Won"
Old 06-04-2023, 12:01 PM
FWIW...
https://www.renntech.org/topic/20057-wheels-offset/
Simply put, if you buy 17's with the same offset and bolt pattern (5x130), they will fit right in. If you buy a larger offset, let us say 55mm instead of the 50mm in the rear, you will most likely need 5mm spacers, if you buy a lower ofset let us say 40mm, you will already be 10mm further out, so no spacers can save you!
Best,
Gus
Old 06-04-2023, 02:20 PM
A930Rocket's Avatar
I used this extensively, when looking for wheels and tires to fit my 330.
https://tiresize.com/wheel-offset-calculator/
Old 06-04-2023, 06:59 PM
pwd72s's Avatar
Old 06-05-2023, 03:15 PM
Based on reading above, I found and bought some Boxster 17” 5 spoke I like. Price was right and should modernize a little. For my purposes, I feel the 17”s ride better and visually make the car appear smaller. That and I’m trying desperately not to spend to much on this one. Thanks all.
Old 06-05-2023, 07:25 PM
