You guys are giving your bikes Brazilians?
You guys must really LOVE your bikes. TMI
Steve '08 Boxster RS60 Spyder #0099/1960 - never named a car before, but this is Charlotte. '88 targa ![]() |
I used to commute to work practically year round in MN. Lots of salt and snow. I would have a spray can of the cheapest lube at work and at home and just hit the drivetrain at each location. At the end of the winter season, I would just replace all the gears and chain. I was running lower end components, so I could almost replace the whole crankset, cassette, rear derailleur and chain for about $100 using NOS off of eBay.
Rutager West 1977 911S Targa Chocolate Brown |
3rd chain update.
I have been riding several days a week and going about 150-190 miles each week and then after my Sunday ride switching the chain. We had rain yesterday and overnight and the roads and trails were very wet and by the time I got home, both me and my bike were filthy. Chain was still clean, no oily film on my rims, spokes and chainstay! Quick hose spray and wipe with a microfiber cloth was all it took to have a clean bike again. Removed the quick link, wiped any moisture off the chain and put it in my used chain box. The one slight pain is putting the quick link on when I put the fresh chain on- takes several tries as even a slight film of wax on the chain doesn’t allow the link the seat in the slot fully. I suspect I will get better as time goes. Rutager
Install the quick link. Don't try to tighten with your hand. Squeeze your rear brake, Push on pedal with your foot and it will pop in nice and easy. No effort.
I will try your way sometime as it would be good to know how to do it if I was somewhere and didn’t have the tool. Thanks.
weekend wOrrier
Here's a pic of the crap that came off my frankenbike chain in the ultrasonic. It had about 400 miles? not much on it including a trip to washington dc and gravel. The cup is kerosene and has settled for three days. The chain didn't look that dirty.
The chain is all waxed and sexy now! Enjoy!!! ![]()
100% narcissist |
Nice!
Well, I went through a month and changed my chain every Sunday; doing between 130 and 185 miles per week. Today I put all the used chains into a pot of water and boiled off the old wax. I’ve heard that you can also just wipe any surface dirt off and re-wax, but I think a quick boil will make it less likely to contaminate the wax pot. My biggest lesson learned through this process was that instead of being a cheapskate and buying a $30 crockpot, I should have spent the extra $50 and got the instapot. They heat up in minutes and temp can be controlled. The crockpot takes about an hour and then you have to babysit it during cooling to get the chain out at the right coolness. I’m absolutely loving the clean driveline. I haven’t ridden in a downpour yet, so can’t say if the wax will hold up, but it should.
weekend wOrrier
lol- I think mine was an "instapot" I got it from my bike shop friend, who bought one, but never used it. I went in and inquired about chain wax, and he had the whole shebang ready as he never got around to it. I had the ultrasonic as a hand me down from a dental office, and it has been a godsend. That chain was relatively clean btw. And the instapot is "instant". The chain / wax/ everything is scalding hot and I'm grabbing the chain like a hot tamale for minutes afterwards! I've been secretly wondering if I could run a pump through the tank, through a filter (oil filter, perhaps hydraulic filter) to get the crap out and recycle the clean kerosene. Lately, I use clean kerosene, dump it into a secondary can, and then use it to start fires on the back 40. It would be nice to not go through so much though. Another project for next week! ![]()
100% narcissist |
I think you should be able to just pour it through a filter screen and get a few uses out of the kerosene.
From my understanding, you should only need to chemically clean the chain once and since the drivetrain is supposed to last a real long time, there shouldn’t be a lot of solvent needed, well, unless you have a large fleet or are doing it as a business. Silca is making a special new chain cleaning fluid that is supposed to be environmentally “safe”.
I do try to put the chain in on top of cold wax, or if not to leave it in for 30 min so its the same temp as the wax. Wax works ok in the wet, but I'd likely rewax at first opportunity. It doesn't do well with wet and road grit.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
I’m not an expert by any means, but the different online/YouTube stuff I have seen suggest that taking the chain out just before it starts to go back to solid leaves more wax inside the rollers. Taking them out very hot allows more of the wax to flow out. I don’t know if it makes a difference, but makes sense to my tiny brain. I put them in around 170F for a few minutes, swirl a bit then turn the crockpot off and with my IR thermometer take them out around 150F. Seems like about 145F the chain slots get clogged up with the wax as it has gotten too cold. Rutager
I got a sample of this stuff at a trade show once upon a time; I found it to be the best lube I have ever used on my recumbent chains:
https://www.royalpurple.com/product/max-chain/ |
weekend wOrrier
I'm always struggling with the line of silt at the base of the cleaner, which smudges everything I put in. Sure, I can dump out the cleaner, and wipe down the ultrasonic tub, but what a waste of cleaner. This gets worse based on a video I watched which states the ultrasonic cleaner needs to be full of liquid not to damage it. True? False? I don't know. Lately, I fill the ultrasonic with something, but put the item to be cleaned in something like a big gulp cup and kerosene to save on kerosene, and dip that into the bath. Also, the "fleet" equation comes into play. My gravel bike will get a run through the wax tomorrow AM. No cleaning at all. Straight wax. My MTB needs the chain and drivetrain run through the ultrasonic before a waxing. My trashcan bike has a chain so clean I could eat off it.
100% narcissist Last edited by LEAKYSEALS951; 07-03-2023 at 04:56 PM.. |
My ultrasonic cleaner has a minimum fill line marked on the side.
Rutager West 1977 911S Targa Chocolate Brown Last edited by rwest; 07-03-2023 at 06:15 PM.. Reason: Grammer |
Finally “got” to ride in a good hard rain for about 15 minutes. Such a good feeling not to have n oily film over the ri s, spokes and chain stays.
A quick rinse with hose and wipe down with a microfiber cloth brought it all back to pretty- no degreaser or mess. After regular rides, I do a quick wipe down with a Silca cleaning cloth before hanging the bike back up. Here’s the uncleaned bike: ![]()
Coffee filters?
Thank you for starting this thread and posting all your updates, Rutager. And for all others who offered their input.
I like the idea of the Ultrasonic cleaner! Here's a YT video I just ran across showing a method without the US cleaner.
Old dog....new tricks..... |
Model Citizen
I'm way too fuggin' lazy to wax my chain. And on a gravel bike? Ha!
But I do have an ultrasonic trick: Put the chain or cogs into sandwich sized tupperware and fill with solvent to cover the parts, put that in the (EMPTY) ultrasonic and then fill the ultra tank with water till the two liquids are at the same level. It keeps the tank clean and it reduces the amount of cleaner.
"I would be a tone-deaf heathen if I didn't call the engine astounding. If it had been invented solely to make noise, there would be shrines to it in Rome" |
I’m positive that the total time involved in waxing the chain is much less than keeping a liquid lubed chain driveline and bike clean- just so much greasy slop all over the rear wheel and bike. Which means either a lot of time degreasing or riding a filthy bike that is slowly grinding all of your expensive gears with a dirt paste!
I have over 4200 miles on this bike and it's never seen any chain lube or chain waxing.
78 SC Targa Black....gone 84 Carrera Targa White 98 Honda Prelude 22 Honda Civic SI |
Thread Tools | |
Rate This Thread | |
