Throw it on the ground!
Can you help me find this chair?
I really like the design of this Adirondack chair and would like to buy or build some. Unfortunately, I haven't had any luck finding it on the Interwebs. The somewhat unique feature of this design vs most is the vertical supports behind the seat back. Thanks!
Mark
1987 911 Coupe
Granite Green Metallic
My Cousin's Wife's Sister's Husband is a Lawyer.
Old 06-20-2022, 05:51 AM
I found a bunch with supports, but not this particular chair. Most of the supports are vertical (vs this one where the support matches the angle of the seat back).
Not the chair, but close-ish
https://pawleysislandhammocks.com/product/3-Piece-Sunrise-Adirondack-Chair-and-Tete-A-Tete-Set/SRAC-TETE-COMBO
Old 06-20-2022, 06:04 AM
A lot of what you find out there these days is going to be a plastic material made to look like wood in colors. It's heavy and supposed to stand up to the elements.
Old 06-20-2022, 06:05 AM
Garage Queen
PorscheGAL's Avatar
https://www.cedarwoodfurniture.com/cedar-adirondack-chair-and-footrest-set.html
https://www.gardenproductsreviews.com/18-best-adirondack-chair-footrests-in-2019/
Stephanie
'21 Model S Plaid, '21 Model 3 Performance '13 Focus ST,
Off to a new home: '16 Focus RS,'86 911 Targa 3.4, '87 930, '05 Lotus Elise, '19 Audi RS3,
Old 06-20-2022, 06:17 AM
Kantry Member
oldE's Avatar
The one Stephanie posted has vertical back supports but has a better seat design.
The image in the op has all the information you need to figure out the build.
If I did build one, I would add a second bolt where the back support meets the seat support/back leg.
Best
Les
Best
Les
Old 06-20-2022, 06:23 AM
I saw a bunch with that sort of vertical support. If you do an image search for adirondack chair, about 25-33% have the vertical back support, except that it's vertical instead of matching the angle of the seat back like in the chair posted in the first post. Visually, that's less appealing.
The shape and lines of the one in the first post is nice.
Old 06-20-2022, 06:43 AM
Shape, lines and design are so important to visual appeal and much of what I see in the Adirondack chair category I don't like. I find this one visually appealing although not as elegant as the one in the first post.
Mark
1987 911 Coupe
Old 06-20-2022, 07:30 AM
This looks similar. I have some items from this place, very good quality (though not cheap).
Chair:
https://www.countrycasualteak.com/teak-adirondack-chair-7205
Footstool:
https://www.countrycasualteak.com/adirondack-teak-outdoor-footstool-7206
EDIT: realized these don't have the vertical supports. Sorry...
1957 Speedster, 1965 356SC, 1965 356SC Outlaw, 1972 911T, 1998 993 C2S, 2018 Targa 4 GTS, 2014 Cayenne S, 2016 Boxster Spyder, 2019 Tacoma
Old 06-20-2022, 08:18 AM
Model Citizen
herr_oberst's Avatar
^ I like that one, that mthomas posted, too. Form follows function. The one in the OP is stylish, I guess, but it doesn't look comfortable, it's just two flat surfaces, so you're sitting on a plank leaning against a plank and you have to use a pillow in the lumbar to find a comfortable position.
Old 06-20-2022, 08:58 AM
Counterclockwise?
I find they need cushions to make them somewhat comfortable.
Folding is good for winter storage as well.
Rod
1986 Carrera
2001 996TT
Old 06-20-2022, 09:26 AM
You do not have permissi
john70t's Avatar
The ones that are angled back are easier on the spine, but you fall into them and can't get out easily. An additional pillow puts you in Apollo1 position so you'll need binoculars to read the paper. Plan your use accordingly. They do look good.
Old 06-20-2022, 09:31 AM
Ayo Irpin, Ukraine!
70SATMan's Avatar
I found the site where the 'picture' was pulled. I think the reason why you are having trouble finding it is because a lot of those gallery 'pictures' are generated graphics. Looks to me like the entire picture is not real but, a graphic. The chair is probably from a model library dropped in to showcase the deck and railing products. Could explain the blockiness of the rear support.
https://www.deckorators.com/en/Inspiration/Gallery
Appears that the graphic is repeated here using a different angle:
https://www.deckorators.com/en/Inspiration/Gallery#gallery-59
Harmlessly passing gas in the grassland away;
Only dimly aware of a certain smell in the air
Old 06-20-2022, 09:59 AM
You are absolutely correct about the difficulty in getting out of these chairs but they sure are comfortable. Our planned use is around the fire pit on the backyard paver patio with cocktails that can be parked right on the arm rest!
Mark
1987 911 Coupe
Old 06-20-2022, 10:59 AM
Yep, that's the site I pulled the pic from - ordered some of there deck rail parts in current project. Your graphics explanation makes sense to me. Thanks!!
Mark
1987 911 Coupe
Old 06-20-2022, 11:05 AM
I've sat in a few, and despite the bottom and back usually being flat, they are surprisingly comfortable. I guess that's why they are so popular.
Wow, that looks about as close as you could get to the one in the original post. THat's a GREAT looking chair!
I'm actually going to save some of the pics. If I ever get a wild hair, I don't think it would be that tough to make somethink like that. Which is good since that's a $1k chair.
Old 06-20-2022, 12:31 PM
Navin Johnson
TimT's Avatar
My brother made some Adirondack chairs using old skis we had in the attic of our garage for the back...
(not the chairs my bro made... very similar)
'69 911 GT-5
'75 914 GT-3
and others
Old 06-20-2022, 02:02 PM
Navin Johnson
TimT's Avatar
He also made a Shotzski out of one of my favorite Nishizawa GS skis ...
Its just some pvc pipe hot glued to the ski... the little red cup shot glasses fit in the pvc pipe stubs...
Feel free to ignore the 4 stooges :-)
'69 911 GT-5
'75 914 GT-3
and others
Old 06-20-2022, 02:07 PM
About 10 years ago, we had an order from the architect that designed the outdoor kitchen, deck and 8 Adirondack out of the same material as the deck board, Ipe. I warned him about how it splinters over time but he didn't care because of uniformity request by the owner. Okay. They turned out to be pretty comfortable. It was a very traditional or true to its original design.
Old 06-20-2022, 02:29 PM
https://niagarafurniture.com/product/niagara-teak-adirondack-arm-chair-ntch006/
Old 06-20-2022, 02:36 PM
