Ethanol Free Gas
Looks like the days of ethanol free premium fuel are gone for my area.
What are people doing for their power tools when every grade of gas has ethanol? Adding fuel stabilizers? Or just live with it?
I have a lot of small engines around, I don't mind paying as bit more to avoid trouble. Marinas have the right stuff, but they are not near me, and racetracks do too, but again, not near me.
Old 06-30-2023, 08:35 AM
Not sure what quantity you’re looking for but I’ve been buying pre-mix ethanol free gas from Home Depot for my string trimmer and back pack blower. It’s expensive, like $20/gallon but my property is small and I don’t use more than 1 per year.
It’s worth it knowing that I don’t have to worry about forgetting to winterize the equipment and it starts right up every spring.
Old 06-30-2023, 08:40 AM
^^^ I started doing the same with the gal cans a couple years ago.
It's amazing how much of a difference it makes in the spring start-up.
78 SC Targa Black....gone
84 Carrera Targa White
98 Honda Prelude
22 Honda Civic SI
Old 06-30-2023, 08:49 AM
peppy's Avatar
I use pre-mix for our chain saws that sit for months at a time. For the weed eater and leaf blower I buy 1 gallon of 93 octane and mix with the synthetic 2 stroke oil.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
1982 Chevette Diesel SOLD
Old 06-30-2023, 08:56 AM
Evil Genius
Rusty Heap's Avatar
I don't have ethanol free within an hour of me, so for equipment that sits, there are cheap $15 carbs on ebay or amazon to replace cheaply instead.
Life is a big ocean to swim in.
Wag more, bark less.
Old 06-30-2023, 09:02 AM
IROC's Avatar
Must be an East TN thing, but it is all over the place here. Are they phasing it out?
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 06-30-2023, 09:19 AM
fancytown
If it's newer equipment I just use standard pump gas. They should have proper fuel lines, gaskets, etc. I have 10 year old equipment that still runs fine.
I always shut off the fuel supply, if possible and run it dry.
Old 06-30-2023, 09:21 AM
We still have ethanol free gas here. The gasohol is 25 cents per gallon cheaper, but I don't ever use it.
My Echo 2 cycle string trimmer is really old, and I had to replace the head not too long ago with the proper Echo branded parts. They changed the design, and it is "new and improved" and sucks big time now. Spend as much time fighting with the line feed as I do trimming.
I just broke down and bought the E-60 56 volt electric trimmer. Carbon fiber shaft, and it has a neat system to reload the line. Just start feeding it in until it comes out the other side, push a button and it self winds the line to the proper point. Get back to trimming.
So far I have only used it once, and it is different than my old trimmer in the way it trims. I will have to change my technique a bit. So far so good. It uses the same battery technology as my electric blower. The blower has a smaller battery as far as amp hours, but the batteries can be swapped back and forth.
So now I will be able to get rid of the last of the two cycle stuff.
My mower and walk behind edger are both 4 cycle.
I have an insane amount of edging and trimming. Just over 1/4 mile of concrete to grass edging with the walk behind edger. And the lots of trimming with the string trimmer along the fence line, and the 10 flowerbeds or tree rings.
So my real option, was embrace the new battery powered blowers and string trimmers.
Also I add Stabil to the tanks of gasoline before I fill them up, even though it is 100% gasoline. My edger is 28 year old. Still starts on the first pull.
Old 06-30-2023, 09:23 AM
Make Bruins Great Again
Por_sha911's Avatar
Here in TN, pure gas is still readily available. It is getting far more expensive but to me its worth it. That said, I still use Stabil Marine treatment all the time and drain the tank at the end of the season and run the equipment dry.
I also run 93 octane no ethanol in the `87 Carrera since it was not built to handle the ethanol and it costs about a buck more a gallon. For the newer cars, regular 10% ethanol is just fine.
To answer your question, use Stabil (or some other treatment of your choice) and don't let the gas sit in the equipment for long periods of time.
Joe
Old 06-30-2023, 11:05 AM
Fleabit peanut monkey
Bob Kontak's Avatar
This is so true. Don't even bother taking them apart.
Not a crime to empty them in the fall but if you forget there's a quick remedy
1981 911SC Targa
Old 06-30-2023, 11:52 AM
canna change law physics
red-beard's Avatar
Not available in Harris County, as it is an EPA non-attainment zone. Waller County (30 miles away) has some stations with G100/E0 gas, but it is about 50 cents higher and only available in regular (89 Octane).
All of my equipment today is rated for E10.
James
Red-beard for President, 2020
Old 06-30-2023, 12:18 PM
LWJ LWJ is online now
Wow! I swear by ethanol free. Run it in everything that isn’t a car.
And...I don’t have issues like everyone else.
I would mourn the loss of this. (Or buy some avgas and cry about the cost)
Old 06-30-2023, 12:22 PM
pwd72s's Avatar
Elections...consequences
Old 07-01-2023, 12:26 AM
@red-beard - All Buccees carry ethanol free fuel (high octane) in Harris County and there is a new P-66 gas station right by my office on Westheimer that does as well.
That's where all the hot rod guys fuel-up.
From a few nights ago:
Old 07-01-2023, 03:06 AM
red-beard's Avatar
Which Buccees is that one? The one I know over in Waller has G100.
James
Old 07-01-2023, 05:06 AM
Por_sha911's Avatar
I'm not sure 100 Av gas is good for my car. Doesn't if have less (or no) additives that most fuels have like cleaners?
Joe
Old 07-01-2023, 06:41 AM
wdfifteen's Avatar
This is a decent web site to help find E-0 gas.
It's not very comprehensive though. Casey's sells 87 and 91 octane E-0 and none of their dozens of stores are listed.
https://www.pure-gas.org/
Old 07-01-2023, 07:13 AM
peppy's Avatar
Not sure about cleaners, but it still has lead in it.
Peppy
2011 BMW 335d
1988 Targa 3.4
2001 Jetta TDI dead
Old 07-01-2023, 11:40 AM
Bob Kontak's Avatar
A kolache non-attainment zone? Nope.
A Gallery Furniture non-attainment zone? Uh-uh
A Buc-ee's non-attainment zone? Not a chance. There's one out past Cinco Ranch.
Perhaps you speak of an Ozone non-attainment zone.
Three years of being the reformulated gasoline EPA attestation auditor for British Petroleum and this is all the fun I get. I'm so old I started when they had MTBE as an oxygenate.
1981 911SC Targa
Old 07-01-2023, 11:56 AM
Still Doin Time
asphaltgambler's Avatar
The short answer = no!......... Ask me why
Old 07-01-2023, 01:32 PM
