Floor jack recommendations
The casters on my Harbor Freight aluminum low profile floor jack have given up their balls. I've checked McMaster Carr for threaded stem casters and nothing is close to strong enough. Some guy on Amazon is selling bespoke floor jack casters for $50 a pair. I'm leery of putting $50 in this POS jack, afraid something else will go wrong soon. Thinking of starting over.
I have a big heavy steel floor jack, but this little lightweight jack is really handy at times. Anyone have an aluminum low profile jack that they like and trust? Light weight is important to me.
Platinum Member
I have 2 of the small cheap light HF aluminum jacks. One I can't kill, it's been outside 10+ years and still works. The other spent a few years in florida, 200' from the ocean. While my tools all rusted, that jack still works also.
If yours is the one I'm thinking of, realize almost all of the weight is on the front rollers. The rear castors don't get 1/2 the force, probably 1/10 or less. Edit: Needless to say my body parts are never under a car supported by any jack. Edit again, Looks like HF sells replacement parts, info on product page on website. $18 for caster for 2T jack
Politics is in the eye of the beholder - Rodney Dangerfield Last edited by dad911; 08-27-2023 at 01:57 PM.. |
https://forums.pelicanparts.com/off-topic-discussions/1138178-aluminum-floor-jack-recommendation.html https://forums.pelicanparts.com/off-topic-discussions/1074774-rubberising-floor-jack-wheels.html https://forums.pelicanparts.com/off-topic-discussions/369719-pos-craftsman-floor-jack.html https://forums.pelicanparts.com/off-topic-discussions/799357-floor-jacks.html https://forums.pelicanparts.com/off-topic-discussions/713790-anyone-using-hein-werner-floor-jack.html https://forums.pelicanparts.com/off-topic-discussions/709445-torin-jacks-do-they-suck-am-i-unlucky.html https://forums.pelicanparts.com/off-topic-discussions/586374-floor-jack.html And there are more...... Good luck! ![]()
Old dog....new tricks..... |
Iv got a bunch of old jacks that dont work anymore measure the height ill see what iv got and send you some
82 SC , 72 914 |
Driver
https://www.hcrcnow.com/shop/parts/hein-werner
I have a Hein Werner floor jack which had a wheel go bad. I ordered a replacement from the above site.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
This is the one that Snap On sued HF over. It is AMAZING. Get one, you won't be disappointed.
DAYTONA3 Ton Low-Profile Super-Duty Floor Jack with RAPID PUMP, Yellow
Tru6 Restoration & Design |
gduke2010
Still have the pvc wrap on my wheels. Thought this would be temporary and still think so. Would like a better solution even though, it's been working for three years.
I really love those AC Hydraulic jacks, but they are heavy and pricey. |
I also have a small HF jack I take to the track, but I need to add oil or bleed it, as it only seems to pump halfway. |
I assume you are talking about the rapid pump comment. The rapid pump thing provides more lift per pump with a corresponding increase in effort. A slow pump makes for more pumps with less effort.
I assumed on Jack rated for heavier lifting have more mechanical advantage. Last edited by masraum; 08-27-2023 at 04:50 PM.. |
OK, I don't think I've ever noticed a difference. I used to have a 50 year old Snap On that had the best release and slooooooow control down I could imagine in a jack but after the piston started leaking and I couldn't find anyone to reapir it and Snap On could not care less, I threw it in the dumpster (a hard day) and got the Daytona. the Daytona lifts my 5000 lb Cayenne easily. If lifting is difficult just get some electrical conduit pipe at Home Depot and add a few feet to the handle length
Team California
Denis For the Epsteinth time, the National Guard troops are just a distraction. The only crime wave in DC is the felon in the WH. |
Didn't HF get sued by snap on for knocking off their jack and rebranding it as "Daytona".....
dolor et pavor Copyright |
My friend bought this, says he will bever use a pump jack again...
https://www.vevor.com/floor-jacks-c_11489/vevor-triple-bag-air-pneumatic-jack-5-ton-lift-jack-11000-lbs-heavy-duty-15-75--p_010978060908
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
Counterclockwise?
The next question should be is what do you recommend for jack stands to go with my floor jack.
Rod 1986 Carrera 2001 996TT A bunch of stuff with spark plugs Last edited by 911 Rod; 08-28-2023 at 11:11 AM.. |
I have 2 jacks.
One is a Craftsman aluminum 2 ton. Works great for lighter stuff. This is my second one of these. The first one used to live in my unheated garage in Northern NY. I was using it once during the winter; I'm guessing it was so cold that it broke in a couple of places, the metal developed a fracture and two pieces fell off. It was still operational but luckily I was able to get Sears to replace it, even though the Craftsman guarantee didn't apply to items other than hand tools. My other is a HF 3 ton. Heavy and much better for my Land Rovers.
Matthew - drove Nurburgring with wipers on and no rain 1969 911E SOLD ![]() 2002 996 Cabrio 1995 993 Carrera 4 SOLD 2004 Land Rover Discovery II G4 Edition (Sold ![]() |
Almost Banned Once
I have one big floor jack that's rated for SUV's (Chinese made). Make sure you buy something robust. Aesthetics or weight means very little because it will be tucked away in a corner of your workshop most of the time. If you need something more portable then look for an alloy jack but they're always more expensive than a steel.
- Peter |
The best for Jack that I've ever seen/used. It's neither lightweight or inexpensive, but it is an exceptional jack. I don't have one.
https://www.pelicanparts.com/More_Info/TOL13HLQ.htm?pn=TOL-13HLQ&bc=c&SVSVSI= Last edited by masraum; 08-28-2023 at 02:03 PM.. |
