Edministrator
Good move, Charlie!
Good post? Leave a tip! O - $1 O - $2 O - $3 |
The mechanic suggested Sea Foam. He's also a tow truck driver and they use it on their diesel trucks.
Charlie 1966 912 Polo Red 1950 VW Bug 1983 VW Westfalia; 1989 VW Syncro Tristar Doka |
Here's a kit to add a filter downstream of the HPFP:
https://whitbreadperformance.com/products/3-0l-tdi-cp4-metering-valve-bypass-kit?variant=44741025857695 |
I’m not sure of seafoam (isopropyl alcohol) in a common rail diesel. Let alone one that has emissions equipment.
dolor et pavor Copyright |
Team California
That is what damages expensive pumps, lack of lubrication that used to be in diesel fuel. Still, these modern systems should be designed to operate well on modern fuel blends but reality is that they do not always, as you have already experienced. |
Parrothead member
Any of the major brand additives will work also. ( Howe's, Power Service....) Some guys use a mix of 2-stroke and Marvel Mystery oil added to their fuel. Was an issue with the 2nd gen Cummins, where the lift pumps were cooking because of the crappy ULSD's lack of lubricity, which in turn would shred the Bosch injector pump. .
Vinny Red '86 944, 05 Ford Super Duty Dually '02 Ram 3500 Diesel 4x4 Dually, '07Jeep Wrangler '62 Mercury Meteor '90 Harley 1200 XL "Live your Life in such a way that the Westboro Baptist Church will want to picket your funeral." |
I think they replaced the entire fuel system; tank injectors pump filter and all lines. |
Team California
