You do not have permissi
(just a note of caution: Do not use Ohm function on a live circuit or the meter will let out extra lucas smoke.)
Meanwhile other things are still happening. |
Monkey+Football
Any accessories installed like a dash-cam that's wired hot?
<Insert witty comment> 85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff. |
Useful thread. I replaced battery on my son’s Jeep XJ and new battery was dead as a doornail the next day :-( Put it on a charger this morning, going to investigate tonight. old car so hopefully the search won’t be too hard.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Born to Lose, Live to Win
I was gonna suggest this as I have to remember to turn mine off…but the camera would be obvious to you
Less obvious would be a laser jammer. Seems highly unlikely but confirm there is no laser jammer installed up front behind the grill….or even a custom install radar detector. Long shot, I know…
Things fall apart; the center cannot hold… 1983 911sc 2025 Chevy Colorado ZR2 |
should be no live circuit with battery terminals disconneted.
drew1 wife has 924 turbo |
I don't know what the charging system is like on a 2014 TDI Beetle - but I had a Mini Countryman, it ate through a couple of batteries in a short time. Would seemingly be OK, drive fine, then parking and nothing, then just dead. As it turned out it had a negative battery cable with what Mini/BMW called an IBS -Intelligent Battery Sensor that told the car when to charge the battery. I replaced the negative cable and all was good. Does the Beetle have something in the charging system like that?
Does it have power seats?
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
Been here a while
My newer cars all have to be reset via OBD scan tool when replacing the battery. Especially when you have something funky with the previous battery.
It seems these AGM batteries have a specific charge cycle depending on the age of the battery. And it seems any OBD tool can reset the battery charging to compensate for a new battery.
looking for 1972 911t motor XR584, S/N 6121622 |
"Now, to put a water-cooled engine in the rear and to have a radiator in the front, that's not very intelligent." -Ferry Porsche (PANO, Oct. '73) (I, Paul D. have loved this quote since 1973. It will remain as long as I post here.) |
Running AGM battery in my old truck. No issues yet but I'm thinking about when present battery goes in wife's 2007 Infinity, replacing with an AGM. Seems like the dealer that scanned for LWJ would have done the reset. One thing I found out on running AGM batteries, if one goes dead it needs a charger that can go into desulfating mode (hope I can can it right) before doing the charge or the charge will not hold. Hope LWJ is getting his daughter's car fixed.
1996 FJ80. |
I find parasitic drains are often one of the most difficult things to diagnose . Sometimes, I get lucky and uncover them in an hour or so, but there have been times, where I am led down the rabbit hole and just cannot devote that kind of shop time when there are 5 more cars out in the lot waiting for service .
Here is what I would do. Remove the battery . Slide a newer toyota or honda under the battery , and roll on . Just kidding, but best of luck with that one . Larger drains. like in your case are usually easier to find .
No left turn un stoned |
^that was funny. www.givesendgo.john70tkeyboard
So we are in the very long and not obvious stage!
After the car sat with 0.01 draw for a day and didn’t drop much voltage, I had daughter come pick it up. I told her to clean it. She did. Yay! I showed her how to measure voltage and write it down. She did. Yay again! She mentioned error lights and said the voltage dropped to 12.45. I told her to come over to swap out the car yesterday. She shows up. Charging at 14.3 v Initial voltage 12.79 Voltage after 2 min load test with high beams 12.59 I called this a good result and sent her on her way with instructions to measure it today and let me know. So. The mystery continues… |
Get something like this, and see when it's dropping. Turn the motor with EngineOffKeyOff and maybe one spot in the alternator has a short. Move the mirrors and seats and windows. Open and shut doors and hood and glovebox. Wiggle the wiring harness. Operate radio. Move keys away and close. Yell "president bomb allahu akbar" into OnStar. Roll the car and maybe wheel sensor is shorted. Turn on lights.
Something is triggering the battery draw. Just need to recreate it. https://www.amazon.com/Cigarette-Lighter-Voltage-Digital-Voltmeter/dp/B00UCEAKYU
^^^wheel sensor???
Maybe this! It does show low tire pressure randomly. Tire pressure is fine. Would a wonky transmitter do this? What a great bunch of geniuses you all are. |
I don't think that year Volkswagen had tire sensors, it just counts the revs using the abs system, and if it counts too many one one wheel compared to the others, it lights the light. To reset a baseline, set the tires to the proper pressure, then press and hold the TPMS reset button, it should be in the glovebox. Hold it until the car "dings".
I changed the rear tires on my Jetta and didn't reset. Everything was fine until I took a trip out of town, about an hour into the trip the car dinged and lit the light, stopped at a gas station and checked all four tires, no issues. The new tires must have been just different enough to trip the system, but it took a long time to do it. |
^^^There are Tire pressure sensors. One or more has failed. A clue. Perhaps.
Most of those should be "off" with the key off. Maybe even weird ECU activity. It is odd.
Still, remember the KeepItSimpleStupid and loose battery plates (bolted down tight?) or something simple like a visor light switch. Make a checklist and go through everything one at a time. There is a puzzle to figure out. You'll be an expert when it's all over. Always wanted a Fluke DVOM but they are pricey. The other yellow brand Inline ammeter with a peak hold and a recall history graph function display would really help find the trigger. https://reviews.chicagotribune.com/reviews/best-multimeters Top rated is only ~$20
Meanwhile other things are still happening. Last edited by john70t; 10-15-2023 at 07:11 PM.. |
^^^That is cool! I need that multimeter gizmo.
