Cherry microswitch
While getting my gas stove up and running, I noticed the remote didn’t work. The receiver on lights up when I hit the remote which is good. I noticed one of the pins on the micro switch had fallen off, basically corroded. I then got screw driver out and took off switch.
I know the make is Cherry. It says DB3 on it and 0.1A 125-250VAC and 0.1A250.
It has two pins.
My problem is the only ones I can find that look like it say DB1. Anyone know what that means or a good source of someone to talk to, electrical always has me stumped. Sorry, can’t upload picture.
Thank you.
Old 10-14-2023, 06:41 AM
Did you trying googling for "cherry DB3 switch"? I got lots of hits, including on Flea Bay.
Seems to be a subminiature used for many things - there was a pinball machine parts supplier listing them.
It has two pins.
Eh? The ones I found all had 3. Or did you mean after that other pin fell off?
DB will be the series.
DB1 seem to be straight pin for the terminals (don't seem to have the plastic clips, but those may be provisions for locating posts/pins on the body),
whereas DB3 have right-handed terminals for board mount with snap-in clips on the body, like this:
Any writing on the body looks to be about capacitance, current rating etc. Some part of the spec, somewhere, will probaby cover NO or NC (Normally Open/Closed).
For parts like this, often cheaper to source a small quantity (like 3, 5 or 10) on Flea Bay than to go to an electronics supplier (like Mouser or DigiKey) that have a minimum order or shipping value...
Good luck!
'77 S with '78 930 power and a few other things.
Old 10-14-2023, 08:34 AM
Thanks, yeah I tried googling and got a bunch of db3 with three pins. The only two pin was a db1. The other issue pf mine has two holes to be able to screw to the system. The db3’s I’ve seen don’t have the screw holes to attach.
Thanks for your help, I appreciate it.
Old 10-14-2023, 08:54 AM
The picture of the 1st one looks just like it but with three pins.
Old 10-14-2023, 08:55 AM
Old 10-14-2023, 09:01 AM
Old 10-14-2023, 09:03 AM
Have you tried to fix the one pictured?
Grind some plastic away, solder, then JB Weld it.
Old 10-14-2023, 09:04 AM
id10t's Avatar
And here I am thinkin we be talking about keyboards ...
Old 10-15-2023, 01:21 AM
LOL. When I enter the part #'s (I think I read mu-40T05 SE4) from your photo(s), I still get cherry microswitches with 3 pins... Maybe there's some other info we're missing - eg that isn't printed on the switch body...
Might be able to figure out the exact part # you need from Mouser - Cherry Switch Catalog
Old 10-15-2023, 12:34 PM
Band.
Buy the three-pin with same amperage rating and use the center pin and whichever side matches your application. (normally closed? Normally open?) Throw a meter on your existing switch and see what it is. Most likely you will just grind off and insulate that third pin that didn't exist on your switch.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 10-15-2023, 01:08 PM
