2-Stoke Fails After 15 Minutes
I have a 2-stroke Shindaiwa backpack blower that has been trouble free for ten plus years. This summer it has been harder and harder to start which turned out to be loose carburetor bolts and some pretty worn out gaskets.
I sealed the carb up and it starts and runs great for 15 minutes or so. After that it won't hold high rpm's. It drops down close to idle speed, then comes back briefly and dies off again. It never stalls, but it won't hold full throttle.
The plug looks good, the fuel lines are good, and when it runs, it runs like a top.
I'm sort of at a loss. It can't be a dirty carb, it runs perfectly at first. I took the fuel vent off, so it's not creating a vacuum in the fuel tank. The spark arrestor is also off right now, there's no back pressure problem.
The only thing I can think of is that the carb is leaking air in when it gets hot and then engine leans out? But I've tried adding some choke as it stalls, and that makes it worse, as does giving giving the primer bulb a squirt while it's dying. I've also sprayed ether onto the carb seals while it's running and there is no surging, so the seals seem to be good. I don't think I have a vacuum leak...
I pulled the cylinder off, the internals are clean and like new, no scoring, almost no wear, the rings look fine.
Maybe I'm losing spark? Maybe it is the plug? I would go get a plug today but they aren't available locally.
I'm stumped and the leaves are piling up. I'm stumped. What have I missed?
Old 11-11-2023, 06:21 AM
Bland
unclebilly's Avatar
Fuel filter plugged? Sounds like it’s fuel starvation to me.
Old 11-11-2023, 06:25 AM
p911dad's Avatar
Gas tank vent plugged up?
Old 11-11-2023, 06:45 AM
I took it off and blew through it, seemed okay. But I do think it's fuel. Maybe I will try it without the filter today. Worth a try. I will order one from Amazon.
Stalls with and without the vent.
Old 11-11-2023, 07:02 AM
Platinum Member
dad911's Avatar
Replace fuel line, ethanol screws them up.
Old 11-11-2023, 07:19 AM
wdfifteen's Avatar
Does it still have a spark arrester screen?
Old 11-11-2023, 07:34 AM
weekend wOrrier
Get a new plug. You've ruled out a bunch of hard stuff already.
marginal gains enthusiast
Old 11-11-2023, 07:59 AM
I replaced one line, the other 'appears' to be okay. I will order some. Ethanol free fuel was available here until this summer, so it has only had ethanol in it for a few months. Also, the primer bulb works fine.
Removed.
On order...
Old 11-11-2023, 08:34 AM
I see you
flatbutt's Avatar
Is the fuel filter one of those sintered metal things? I've been able to blow air thru them but they still didn't pass fuel. But the 15 minute thing is odd.
Old 11-11-2023, 08:37 AM
rsrfan's Avatar
Check the muffler. Used to own a landscape company and the stihl backpack blower spark arrester screens plug up and they stall out when hot…
Old 11-11-2023, 10:06 AM
Muffler is 100% clear.
Old 11-11-2023, 10:10 AM
rsrfan's Avatar
Sorry, did not see that. It “might” be the coil. When they get older they can fail when hot then work again when cooled off…
Old 11-11-2023, 10:15 AM
greglepore's Avatar
I have a stihl chainsaw (like 30 yrs old) that bogs like that when it gets hot. I need to swap the plug-my suspicion is that it either opens the gap up when hot beyond marginal or something in the insulator/electrode.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 11-11-2023, 10:49 AM
You do not have permissi
john70t's Avatar
Gas would happen at all times (or randomly) so I second heat-related coil or plug.
Old 11-11-2023, 10:51 AM
I cleaned my plug and re-gapped it, but I also pulled the front half of the in-tank fuel filter off.
It 'appears' to be fixed, but now I regret making two changes at once; since I posed the problem here I would like to post a definitive solution.
New plug and filter on the way from Amazon.
Thank you for your suggestions, I think it was fuel (as BB suggested above), but I have a bit more R&D work to confirm, I will reassemble the fuel filter and see if it fails me tomorrow.
Old 11-11-2023, 11:21 AM
Fleabit peanut monkey
Bob Kontak's Avatar
Originally Posted by 1990C4S View Post
....but I also pulled the front half of the in-tank fuel filter off.
Was there dirt in the tank? I have seen filters pack up with crud after 15 minutes and bog way down including stalling. Let it rest a half hour and the dirt falls out and it runs normal again for a little increment.
This was on a riding mower though but same concept should apply.
1981 911SC Targa
Old 11-11-2023, 11:51 AM
I will check, that's not a bad supposition. Very old blower, large tank, never been cleaned....yea, I am guessing it's dirty.
Old 11-11-2023, 11:55 AM
I'm 99% sure the problem was the in tank fuel filter. I installed the new one today and it runs great.
Inspecting the old one, I would say that ethanol was dissolving the white metal body of the filter. I had the same issue with a moped carb a few months ago. I generally find that two strokes handle the ethanol better than four strokes, but I guess it's a problem in all my small engines now. I will empty the crab and soak it in trans oil of Marvel Mystery Oil before it goes away for the winter.
Thank you to everyone who suggested some of the things I missed.
Old 11-12-2023, 10:47 AM
Separate the water out of the ethanol gas and quit running ethanol gas through your blower.
"Masculine republics give way to feminine democracies, and feminine democracies give way to tyranny." *** Aristotle
Old 11-12-2023, 12:19 PM
greglepore's Avatar
Yeah, we're lucky to have ethanol free available here at the pump. Stopped using regular gas in power equip this year, after replacing several carbs. My small engine guru swears by seafoam (an ounce per tankful) as a fuel stabilizer in anything that sits.
Greg Lepore
85 Targa
Old 11-12-2023, 01:00 PM
