Shaun @ Tru6's Avatar
Safe to leave transformer open?
Just wired in a new 208V to 230V boost transformer for my compressor. These things get hot so I both mounted it on my old compressor tank for 360º cooling and left the bottom cover off.
Any reason why the cover is necessary in this scenario?
Tru6 Restoration & Design
Old 11-26-2023, 01:59 PM
When you invite the first grade class field trip in, you may want to have it covered. Otherwise, I wouldn't think it would be a big deal.
Old 11-26-2023, 02:33 PM
id10t's Avatar
rodents or bugs? im especially wondering about biters or stingers
nm indoors
Then only if you are subject to aby kind of inspection
Old 11-26-2023, 04:06 PM
The lower cover is part of the ground path if wiring shakes loose and has to hit something...
Old 11-26-2023, 04:50 PM
UnRegistered User
billybek's Avatar
Cover keeps someone from running a fishtape, wire or random object into the marrette or wire nut connection. Better to have it covered.
Bill K.
Old 11-26-2023, 05:30 PM
Good thoughts, thanks, I hadn't thought of these. The yellow compressor is just a tank so it's not vibrating, which I know all about since just the other day I put my wine decanter on top of a speaker and then a good song came on the radio so I turned it up and the decanter vibrated off and shattered pretty spectacularly.
Bill, the compressor is in a storage room that only I would go into but your point is well taken.
Old 11-27-2023, 03:45 AM
