LWJ LWJ is online now
I like Fred’s answer. “Hammer Function.” Genius.
Old 01-05-2024, 11:17 PM
wdfifteen's Avatar
Originally Posted by Scott Douglas View Post
My Crescent wrenches have always doubled as micrometers.
Some of them are older than I am as they were my dad's.
Now there's an idea! I always thought my Chinese combination micrometer/welding clamp was a great tool, but adding in the adjustable wrench function would make it a tool you could sell on YouTube.
I have 3 work areas spread out over the property and keep at least an 8" or 10" adjustable in each one, plus one in my tractor tool box and one in my golf cart tool box. I have some hanging on the wall in my main shop. I have so many duplicates because an employee was stealing my tools. I replaced them, then found the originals (long story). I still have the 10" genuine Crescent wrench my dad kept in the tool box of his John Deere 520.
The blue 2" wrench is not much more than a toy. I've had the 4" Crescent brand with the yellow handle for 50 years. The 6" is a new Crescent brand made in Spain (OK quality). The rest are old non-Crescent but good Made in USA wrenches.
On the subject on proper use of tools, it's never too late to learn. I've been using screwdrivers for decades, but I remember a tutorial Zeke gave here on proper use of a flat blade screwdriver and thought, "Damn. I didn't know that!"
Old 01-06-2024, 03:13 AM
That’s a great set of nut rounders ya got there!
Old 01-06-2024, 06:34 PM
Preferred pronoun:Maestro
Norm K's Avatar
Originally Posted by fastfredracing View Post
I hope I am using the hammer function correctly
This!
One thing he didn't clarify in the video, though, is whether this is an issue with metric versions too, or SAE only.
_
When in doubt, use overwhelming force.
Old 01-06-2024, 07:14 PM
Jeff Hail's Avatar
Adjustable Metric Spanners are handy.
Jeff Hail
"All men dream: but not equally. Those who dream by night in the dusty recesses of their minds, wake in the day to find that it is vanity; but the dreamers of the day are dangerous men, for they act their dream with open eyes, to make it possible"
Old 01-07-2024, 11:50 AM
pwd72s's Avatar
Project Farm did a test...interesting results. 20 minutes.
https://www.youtube.com/watch?v=cyOd05PUix4&ab_channel=ProjectFarm
Old 01-07-2024, 11:54 AM
Bill Douglas's Avatar
Yeah. I threw away all my adjustable imperial ones. It got too confusing having the two systems.
Old 01-07-2024, 12:00 PM
Super Moderator
cstreit's Avatar
I'd like to see a stress analysis of this. Wouldn't the top and bottom be receiving equal force if the jaws are tight?
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-07-2024, 12:13 PM
Originally Posted by Crowbob View Post
I also saw a person loading a paint roller by dipping it into a can of paint.
What an imbecile. Everyone knows to splash the paint on the wall from the can and then roller it even.
Old 01-07-2024, 01:37 PM
WPOZZZ's Avatar
Don't be silly guys, I have both!
Old 01-07-2024, 02:50 PM
Zeke's Avatar
I think so, but the the lower jaw has less mass and is not as strong. The work doesn't care.
Old 01-07-2024, 05:15 PM
wdfifteen's Avatar
I don’t think so. Rotating the wrench towards the movable jaw creates a moment at the tip of the jaw. Rotating away from the movable jaw creates a moment at the base of the jaw. The moment arm from the tip of the jaw to the pin that the adjuster barrel rotates is longer than the moment arm from the base of the jaw. The extra bending force against the pin is more likely to bend the pin and mess up your wrench.
Old 01-07-2024, 05:39 PM
A930Rocket's Avatar
I can’t remember which way I was using the crescent wrench, but after putting a lot of force on it, the adjustable part popped off. It was a good brand-name crescent wrench also. I should’ve been using a socket though.
Old 01-07-2024, 06:51 PM
Super Moderator
cstreit's Avatar
I see what you're saying. You want the moment of force further out on the stronger "top" portion. ...but wouldn't this mean you should do it backwards?
This guy suggested the first direction, but I would think the second is better?
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 01-07-2024, 07:37 PM
jyl jyl is online now
jyl's Avatar
That’s what I initially thought (that counterclockwise is better). But adjustable wrenches don’t fail by the adjustable jaw tearing off, they fail by the adjustment mechanism (worm gear, teeth) getting damaged. Counterclockwise tends to force the adjustable jaw to slide, which means the force is being applied to the adjustment mechanism. Clockwise adds a rotation force to the adjustable jaw, which is resisted by the sliding parts, thus distributing the force between the adjustment mechanism and the siding parts.
That’s my theory anyway - explained it in more detail above. Whether it’s true - someone should take a couple cheap wrenches and abuse them to see.
Old 01-07-2024, 08:04 PM
Model Citizen
herr_oberst's Avatar
The wrench grips and turns the edges of the fastener, not the sides.
Old 01-07-2024, 09:26 PM
911_Dude's Avatar
Ridiculous. If the tool cant handle going either way its a junk tool. Ive used a adjustable wrench my entire life for various things and never have given the direction of rotation a thought. Also, never had an adjustable wrench break or bend. To me this falls into the category of debating the orientation of the Porsche crest on the wheel hub.
Coincidently, I just recently bought a Knipex gear drive adjustable. Great tool. The old Cresant screw type will see little use now.
Old 01-08-2024, 08:16 AM
pwd72s's Avatar
Way I see it as well. The weakest point of the wrench is the worm gear/teeth...
Old 01-08-2024, 10:24 AM
CurtEgerer's Avatar
Do we really need a 5-minute tutorial on using an adjustable wrench When using adjustable tools of any kind, quality/precision is particularly important. Pay the extra $$, get the best adjustable wrench (most are horrible), and you'll be able to use it backwards, forwards, upside down or as a small hammer in a pinch.
1983 AUDI Turbo Ur quattro
1987 PORSCHE 944 turbo
Old 01-09-2024, 05:34 AM
You do not have permissi
john70t's Avatar
Hah. I represent that comment so please retract at once, sir!
Put in a kitchen ceiling light a few weeks ago but the paint needed touch up. Half empty old 5gal bucket of Glidden ceiling white using a drill and long mixer cage to pulverize it first. A 2ft extension handle screwed on and worked from floor. Roll it gently across the surface of the bucket paint and shake it out inside. The drips happen when the roller gets fill up inside and at the edges. Roll edges a bit harder first inside the line and go over it again.
Didn't even use a drop cloth but covered the stove with cardboard. Only a few small drips. YeahI live dangerously.
Turning a crescent 'the right way' forces the adjustable jaw into the frame. Brown arrows.
(I mostly use them for holding a valve still or larger nuts which can't be chewed up)
Old 01-09-2024, 06:41 AM
