LWJ LWJ is online now
What do y’all know about generators and dirty power?
So my house lost power for a few days. It was cold. I borrowed (with conversation on buying) a generator and wired in my furnace's. The fan blowed but the igniter didn’t fire. Polarity was correct as I checked it. The cord has a ground.
Power came back. My furnace works.
I am happy to buy this generator but I think the output is too dirty to run my furnace.
Thoughts?
Furnace is an old Trane and is on last legs.
Generator is a Generac brand inverter style.
TIA!!!
Old 01-16-2024, 11:52 AM
id10t's Avatar
What is the peak draw to charge up and use the igniter? Did the generator have enough of a rating to provide that (as well as overhead for fan or whatever else was running on it already)
Old 01-16-2024, 12:23 PM
Inverter generator is pretty much as clean as it gets. What size is the generator?
Old 01-16-2024, 12:41 PM
908/930's Avatar
Is the furnace a condensing type? Condensate tank full not allowing furnace to turn on?
Old 01-16-2024, 12:51 PM
It’s on 2000w. Don’t know draw. Condensate is fine.
That might be the issue. Too small for peak draw. Hmm. I will research. Thanks!
Old 01-16-2024, 12:54 PM
The google machine says 2000w inverter type should deliver over 16 amps. I'd be surprised if a furnace required much more than that since that's the max you'd connect to a 20A breaker which is how a furnace is typically fed.
Old 01-16-2024, 01:05 PM
jyl jyl is online now
jyl's Avatar
"2000 watt" generator may refer to peak power, running power may be 1500 watts, at 120 v that's about 12.5 amps. Seems should be enough for a furnace, but look at your furnace's info plate to see its motor draw.
Old 01-16-2024, 01:08 PM
John Rogers's Avatar
I bought two at HF and both run great! One for down stairs frig/freezer/lathe/ETC and heater and other is for upstairs frig and lights. Both have wheels, handles and run all night on one tank of gas which was used back in 2007 when we had a big fire in the San Diego area. They saved my late daughter's and late wife's medicines.
John the oldracer
Old 01-16-2024, 01:13 PM
908/930's Avatar
Do you have a AC or heat pump tied into the furnace? Im thinking an interlock relay somewhere else is not turning on.
Old 01-16-2024, 01:17 PM
wdfifteen's Avatar
Length and size of the cord could have something to do with it.
Old 01-16-2024, 01:18 PM
Model Citizen
herr_oberst's Avatar
Did your circuit board lamp throw any codes while you had the generator hooked up?
Old 01-16-2024, 02:07 PM
Zeke's Avatar
Funny that this thread appeared. Yesterday I was deep in study about using a genset to run a welder. I was on WeldingWeb after a 9 year absence. I found out what I need to know and a lot more when this link was offered:
http://www.screenlightandgrip.com/ht...enerators.html
Craigster?
Anyway, circuit boards don't like generators all that much. Of course YMMV. But they are fine with resistance heating and incandescent lighting all day long. I assume older fridges and freezers won't have a problem.
Anyway, and I don't have a recommendation, an electronic filter can clean up the power and provide a distribution system whereas you really don't have to hook up through your panel. You really must disconnect what you power through the generator and not feed the house in any way w/o a lock out transfer switch.
The quick take away from the link is that there are 4 types of generators. Not just talking about inverters vs. conventional.
Old 01-16-2024, 02:27 PM
Slackerous Maximus
HardDrive's Avatar
I can tell you that I ran our furnace a few years ago off a Honda 2200 without issue. It was also also powering cell phone chargers and internet router.
Are you sure there are not 2 separate circuits to the furnace? Is the thermostat some new fangled thing with a separate power source?
2014 Cayman S, PDK
Old 01-16-2024, 04:25 PM
Super Moderator
cstreit's Avatar
Dunno about generators, but once had a gererator that was super clean.
..if you don’t get this, you ain’t an old timey Pelican.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-16-2024, 08:58 PM
I have a Harbor Freight 10kW. I would never use it for anything sensitive, no TV's, and not my new fridge.
It's fine for motors, heat, water heater, deep freeze, and lights.
I suspect the OP's problem was voltage drop. Try again, and use a Fluke max/min meter at the furnace to measure the voltage.
The more sensitive devices should be powered by an inverter generator.
Old 01-17-2024, 08:14 AM
3rd_gear_Ted's Avatar
Is there 24 Vac control power to the furnace and T-stat also?
1980 911 - Metzger 3.6L
2016 Cayman S
Old 01-17-2024, 08:31 AM
Evil Genius
Rusty Heap's Avatar
In 25+ years of running "affordable" 5-10KW generators, I've never had an issue with computers and TV's and such. Just check the spec's. To power sensitive equipment, you need a generator that produces a THD of less than 5 percent, also known as clean power.
Life is a big ocean to swim in.
Wag more, bark less.
Old 01-17-2024, 09:08 AM
jyl's Avatar
For what its worth, I test ran my furnace from my Harbour Freight inverter generator just now - was fine. But its a 9500 watt generator.
Old 01-17-2024, 12:21 PM
