Not without an elbow...and not sure what thread that is. The gauge uses m6. If you want to play, send me a pm and I'll drop it in the mail, its excess.
Greg Lepore 85 Targa 05 Ducati 749s (wrecked, stupidly) 2000 K1200rs (gone, due to above) 05 ST3s (unfinished business) |
Done, and thank you very much. I really appreciate the help and generosity.
1989 3.2 Carrera coupe; 1988 Westy Vanagon, Zetec; 1986 E28 M30; 1994 W124; 2004 S211 What? Uh . . . “he” and “him”? |
Interesting video on cycling pump to achieve pressure profile rather than using a flow control
Ive got the same flow control and it doesnt annoy me at all. A good shot will diverge a bit from perfect pressure but the change is gradual and easy to anticipate. Its actually kind of fun to drive the shot. That guy seems like he wanted to build something complex. In my eyes a lot worse than the flow control switch. To each their own i guess. |
But yeah, vid was weird-some sort of AI voice?
I dont think hes a bot, but this is the sort of disinformation video that will become common in the future when the bots rule us all. The whole video is just so weird! |
![]() Looky what came in the mail! I’m excited to try this out, need to find an appropriate threaded tube. Looks like it belongs in a 911, doesn’t it? Thank you, greg, thank you very much!
No worries. It was excess baggage.
Hmmm....These guys seem to have it all figured out:
(the shotguns)
In a bit of a groove with our machine of late. Found local beans that give a solid result and figured out I wasn't purging the steam wand long enough. I was getting the occasional watery...I dunno cortado or flat white I guess?....and it sucked. Now with longer purge that problem is gone away.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. |
I was having issues with sour shots. I tore the machine apart and did a super cleaning. That helped a lot. I then bought new IMS shower screen and basket screen and a scale and some other things. it took quite a bit of messing around to finally get a decient shot and I still struggle with lighter beans. I really dont want to send it in to get checked out as the machine is heavy and cost quite a bit to ship the last time.
1982 930, K-27, BL adj. WUR, Rarlyl8 Headers and Hooligan muffler, PK CDI, 22 and 30mm torsion bars, poly bronze bushings 30mm raised spindles and custom valved Bilstein shocks (by Elephant Racing), monoballs front and rear (by Rennline), Alton 17" Fuchs, Fred Cook fuse panel |
My wife and I had a Delonghi Magnifica Espresso machine for the last 20+ years; it served us well but finally gave up. I decided it was time to upgrade and bought a Breville Barista Express Impress. We both love it. The coffee is as good as, if not better, than going to Peet's or any other coffee shop. Easy to use and clean. Been using it for over 2 months and it is flawless; I give it 5 stars!
'71 914-6 #0372 '17 Macan GTS |
FWIW, if you have issues with bitter/sour shots, try turbo shots for a while. I was skeptical, but they're ok. Not trad espresso, but tasty nonetheless.
(the shotguns)
Wife picked a bag of this up for me at a local shop.
https://www.brandywinecoffeeroasters.com/collections/all-coffee-1/products/galactic-standard-espresso-blend-16-00 Roast date was the day before and my first brew was too sour and unpleasant. Tried a few more times and figured it wasn't for me. Then about a week after getting it I tried one more before giving it away. BIG difference! It is the least bitter and smoothest bean i've used so far. I guess they aren't kidding when they say to give the beans some time after roasting. Noticeably different from the Rise Up beans we normally get. I'm a fan. i'd say it looks like a medium roast. I am doing 19 in, 34-35 out at about 30 seconds per the website.
***************************************** Well i had #6 adjusted perfectly but then just before i tightened it a butterfly in Zimbabwe farted and now i have to start all over again! I believe we all make mistakes but I will not validate your poor choices and/or perversions and subsidize the results your actions. Last edited by berettafan; 04-25-2024 at 06:17 AM.. |
Hmm, I don’t think I ever buy fresh enough beans to have this issue?
(the shotguns)
was dumb luck on our part. I don't drink a ton of coffee and found larger bags or long ago roast dates can get pretty lousy towards the end. Maybe it's just a change I need to make to grind or something to account for age? For local roasters I check roast dates when buying.
I have been around peers who slide down the slippery slope of finding their perfection over a simple shot of espresso. It is very slick and costs and time come into play if you are not careful. We love good food, nice wine, and a great jolt in the morning. Only hope the OP does not follow the rabbit hole to "if only it could be better". Drive over to your local 7/11 and drink a cup of their swill for a correction. Your brew, on it's worst day, blows that stuff out of the water. |
https://youtu.be/tU1y7hBSgiY
Some sound advice from one of my favorite coffee YouTubers. “Drink bad coffee”.
(the shotguns)
Dropping back in to say I continue to really enjoy the brandywine galactic standard beans. Using an 80:20 2% to half and half milk mix with it and it’s just delicious.
Snark and Soda
Good post? Leave a tip! O - $1 O - $2 O - $3 |
