A930Rocket's Avatar
Power steering cooler question
Is it possible to braze or weld or ? these two power steering cooling lines to make one? The black one is stock and the bare aluminum with fins is off a later model BMW. Or do you think using high-pressure hose and clamps will suffice?
Old 03-31-2024, 05:06 PM
Arizona_928's Avatar
Looks like the finned one is soldered.
I would imagine a similar method could be used (thinking of custom hvac hard lines)…
dolor et pavor
Copyright
Old 03-31-2024, 07:39 PM
A930Rocket's Avatar
That’s what I thought, but I’ve never heard of brazing or soldering aluminum.
Old 04-01-2024, 12:42 AM
Is it on the supply or return line? The return side will be low pressure, and any 'decent' clamp will work.
Old 04-01-2024, 06:12 AM
Zeke's Avatar
You can braze al with zinc. There's all kinds of Muggy Weld type of products out there like the ones you see filling the hole in a soda can. FI hose clamps would be fine if they are the correct size.
Old 04-01-2024, 08:01 AM
A930Rocket's Avatar
Thanks guys. I’m going to see if I can un-braze the joint on the new one and go from there.
I’ll have to look and see if it’s on the high side or low side.
Old 04-01-2024, 11:15 AM
I used one of these on my ATF line.
https://www.ebay.com/itm/163508819410https://www.ebay.com/itm/163508819410
I did have to mill the aluminum line slightly with sandpaper due to it being a but thicker than copper.
Old 04-01-2024, 12:28 PM
fastfredracing's Avatar
They are always on the suction side, just use the correct type of universal power steering /transmission/ hydraulic return line, and good spring clamps to loop them together , then .....
No left turn un stoned
Old 04-01-2024, 03:07 PM
A930Rocket's Avatar
Hahaha, Fred!
I was able to un-braze the fittings on the new cooler and used a piece of it to make a splice. Unfortunately, the pipes are not the same size and it’s a little big for the old pipe and a little small for the new pipe.
It’s also about 1” too long right now and I need to see if I can shorten it up somewhere.
For $16 I’m going get a small tubing expander off Amazon and see if I can expand the old pipe and the fitting….
Old 04-01-2024, 03:44 PM
You have brake line flaring tools? If you have the ones that make bubbles they may work.
I’m spoiled - have one of those $200 hydraulic deals with a ton of dies that I bought when I was redoing the stainless lines to my hydroboost setup, but even the cheap ones work if you go slow.
Old 04-01-2024, 06:00 PM
