G50 G50 is offline
Originally Posted by 908/930 View Post
Is the contacts that fails on that first relay? If so I'm still thinking you are getting some voltage spike back from the fan relay coil.
Idk. It stops working, I change the relay and it works again.
One of the times it failed, if I tapped on the relay with a wrench, it would get going.
Old 04-30-2024, 03:39 PM
G50 G50 is offline
Is it possible I have the relay wired wrong?
If it was wired incorrectly, would it work at all (even temporarily)?
Old 04-30-2024, 03:56 PM
908/930's Avatar
Your sketch looks correct. Could it work if wired wrong, well it would be able to work if the wire from term 85 (the ground side of your first relay coil) went to your other relay coil, then you would have both coils in series and your switch would energize both coils. Try a lower rated relay, there is a chance that the contacts in that 30A one do not get far enough apart. Check the wire diagram for the other relay though, does it only have 4 terminals to plug into?
Old 04-30-2024, 04:47 PM
Originally Posted by G50 View Post
It’s parallel.
When I hit the dash switch the fan comes on, no matter what temp the radiator switch is at.
That's what I'm thinking there's an issue with having 2 switches in parallel. I can't remember what the issue is, but I've run into this before. I think having 2 switches on one circuit requires some other mechanism to ensure that you don't have issues, which is part of the reason why there's more to wiring 2 way light switches than just sticking in an extra switch.
Old 04-30-2024, 04:48 PM
908/930's Avatar
I don't think that will be a problem, as long as the ground is the same for both. Different with house wire because you want to be able to turn on and off from each switch.
Old 04-30-2024, 04:59 PM
G50 G50 is offline
Here’s the diagram. It’s the high speed temp switch im piggybacking on.
Old 04-30-2024, 05:24 PM
908/930's Avatar
80's BMW? Looks very similar to my E28 circuit.
Place an amp meter in series after your relay or at the coolant temp switch just to check how many amps it is seeing, that side is fused at 7.5A so should not be much.
Old 04-30-2024, 06:45 PM
G50 G50 is offline
E24, so similar to your E28.
I’ll check with the amp meter, will have to wait for my new relay to get here.
Old 04-30-2024, 07:26 PM
You added a physical switch, correct?
Why have a relay at all? you're "switching" the low current coil side of another relay, you can just put the switch in line and toss the extra relay.
Also, I'm concerned that what you're getting is a feedback loop. Are the new relays dying when the radiator is at high temp? You might be getting a loop where the temp switch and the relay flutter when the temp switch closes.
Mike Bradshaw
1980 911SC sunroof coupe, silver/black
Putting the sick back into sycophant!
Old 04-30-2024, 08:55 PM
G50 G50 is offline
Yes, it’s a physical switch.
I added the relay because the switch has a light bulb in it. I rigged it so the switch lights up when it’s activated (like a typical AC switch).
I can’t see any other way to accomplish that without a relay, but I’m open to suggestions.
Old 04-30-2024, 09:46 PM
908/930's Avatar
Just checking that you are not feeding the coil of the relay through the light bulb?
Old 05-01-2024, 12:34 AM
G50 G50 is offline
It’s possible that I am. It’s been a while since I made the modified switch, I don’t remember exactly what I did.
I did make a drawing at the time, but looking at it I don’t really understand the switch part. It of course made sense to me at the time, but now I’m not sure what it means. (But I suspect it may be feeding the coil through the light bulb).
Old 05-01-2024, 06:24 AM
G50 G50 is offline
It’s an LED bulb, if that matters.
Old 05-01-2024, 06:25 AM
908/930's Avatar
You show a ground wire going to the switch so you are probably ok but check it anyways. I was thinking that if you had the light in series with the relay that would limit the power going to the coil and could explain the short lifespan, light would work fine but relay would not.
Old 05-01-2024, 09:21 AM
3rd_gear_Ted's Avatar
Use a current rated PNP transistor circuit for ground switching.
That is how industry does it.
1980 911 - Metzger 3.6L
2016 Cayman S
Old 05-01-2024, 12:14 PM
G50 G50 is offline
Interesting. Looks like I need to use a diode to protect it?
I’ll have to dig into this, on first read it’s above my current (pun intended) level of understanding.
https://electronicsclub.info/transistorcircuits.htm
Old 05-01-2024, 12:20 PM
908/930's Avatar
One thing I do not like about transistors is when they fail they can remain on, relays usually fail off. If you are having problems keeping a relay working SSR will likely be less reliable.
Old 05-01-2024, 12:45 PM
G50 G50 is offline
Maybe I can eliminate my add on relay?
How about wiring like the bottom diagram?
Old 05-01-2024, 01:44 PM
908/930's Avatar
That should work, but the relay you have in there now should also work. With that new setup make sure you have a fuse where you pull the power for the light by the fan, or have wire rated for 30A. I still think you should try a lower 15 amp rated relay in the existing setup.
Old 05-01-2024, 02:21 PM
G50 G50 is offline
Ok, I’ll try a 15 amp relay tomorrow.
If that doesn’t work, I’ll try the alternative wiring with a fuse.
Old 05-01-2024, 02:35 PM
