id10t's Avatar
298mph drone....
Link with more - https://petapixel.com/2024/05/09/photographer-smashes-world-record-for-fastest-drone-flight-at-298-mph/
A photographer and content creator has set the world record for the fastest drone flight after his custom-made aircraft achieved a staggering 298.47 miles per hour (480.2 kilometers per hour). Guinness confirmed the record noting that Luke Maximo Bell and his father Mike achieved the "fastest ground speed by a battery-powered remote-controlled (RC) quadcopter."
Luke, who has previously turned his GoPro into a tennis ball, describes it as the most "frustrating and difficult project" he has ever worked on after months of working on prototypes that frequently caught fire. From the very first battery tests for the drone that Luke calls Peregrine 2, there were small fires as it struggled to cope with the massive amount of current which caused it to heat up to over 266 degrees Fahrenheit (130 degrees Celsius). The motor wires also burst into flames during full load testing causing Luke and Mike to use thicker ones so they didn't fail...
After 3D-printing the final model and assembling all the parts, Luke took it for a maiden flight which immediately resulted in yet another fire. This setback made Bell almost quit the project but he decided to remake all the parts and try again — which also ended in fire. This second catastrophe prompted Luke and his Dad to "completely redesign the whole drone body." It meant weeks of work as the new prototype was once again tested, 3D-printed, and bolted together.
Old 05-13-2024, 06:49 AM
I suspect the military has faster drones. But yea, that is fast. How does he stay within FAA rules of line of sight control?
Old 05-13-2024, 07:20 AM
id10t's Avatar
Well, so far the smoke trails seem to help....
Old 05-13-2024, 12:48 PM
