My other ride is a C-130J
Transformer/Voltage/Amperage/Gauge?
I am adding a security camera to my house. The current camera is on the corner of my house pointing north. I want to add the same type of camera pointing east located on the corner of the house 3 inches from the original camera.
The cameras came with a 5v 1.2 A transformer. Each camera works with the current wiring. I spliced into the wiring and added a second plug for the second camera. I replaced the original transformer (5v 1.2 A) with a new one 5v 3.0 A. With both camera’s plugged in only one camera works at an time.Each connection delivers 5.01 volts. Essentially only one camera works at a time with the new transformer. The only thing I can think is the problem is the gauge of the existing wiring is wrong and affecting the electrical current. Any ideas ? Thanks in advance.
1975 911 Targa S 3.0 2000 911 Carrera Cab 2005 Cayenne Titanium Metallic 2022 Mercedes-Benz E450 Coupé 2020 Mercedes-Benz E350 2006 ACG Hummer Previously Owned Art from Stuttgart 2000 Boxster -1983 911 SC Cab -1984 944 N/A |
I'm thinking both cameras are using the same radio frequency (something like 2.4GHz) and only one can use it at one time.
That’s a good suggestion Bill, but these camera are WiFi at different Internet addresses (192.162.0.101). I’ve got 6 other WiFi cameras hooked up with no interference.
I ended up running a second wire the same gauge as the original wiring from the second camera spliced into to the original 5 v 1.2A transformer. Both cameras work. So the issue was the thickness of the wire. So thanks for listening everyone
How long was the wire to the cameras? 1A per camera is quite a bit of juice.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
4 1/2 yards
Good thinking! I'm pleased you got it sorted.
Both GF at her house, and me at my small commercial unit, are looking into cameras. She is thinking of a Eufy setup and I'm looking at Ubiquiti UniFi cameras. Do you have any thoughts regarding these or a better option? |
Evil Genius
Life is a big ocean to swim in. Wag more, bark less.
