Best tool for job
I want to remove welds from boxster muffler. In tight spot. Trying to remove tips. My grinder wheel is too big without grinding other parts of muffler.
Old 08-15-2024, 04:49 AM
Bland
unclebilly's Avatar
Can you remove the muffler to improve access?
Old 08-15-2024, 05:08 AM
That's what popped into my head as well. Isn't the muffler assembly just bolted on? Once it's out then there should be more room for more tools.
Old 08-15-2024, 05:10 AM
Sorry, muffler off car on bench.
Old 08-15-2024, 05:18 AM
Shaun @ Tru6's Avatar
Astro Pneumatic Tool 218 1/8" Pencil Type Die Grinder - 56,000RPM,Black,gold,blue, 42377
Tru6 Restoration & Design
Old 08-15-2024, 05:25 AM
Old 08-15-2024, 05:31 AM
Looking at tools, probably better off just having muffler shop grind off. It’s a one time job.
Fleabit peanut monkey
Bob Kontak's Avatar
Why wouldn't you post a picture of your muffler?
Shaun's kit is awesome. I'm not so sure a muffler shop is going to have better than that for close quarters.
1981 911SC Targa
Old 08-15-2024, 05:44 AM
I tried, my phone didn’t cooperate.
It’s not that a shop won’t have a better tool, it’s that it is probably a 1/4 the price for something I’ll likely never use again.
Old 08-15-2024, 05:59 AM
Old 08-15-2024, 06:01 AM
Carbide burr on an die grinder, liker Shaun posted.
Do you want to salvage the tip? Or is it going to be scrapped? What's the end goal?
If the tip is scrap, go at with a zip cut on a grinder.
Old 08-15-2024, 06:06 AM
What the heck, I just bought Shaun’s tool. If it don’t work, I’ll use it to shape rocks.
Thanks all.
Old 08-15-2024, 06:07 AM
Dremel Max Life 9903HP 1/8" (3.2mm) Tungsten Carbide Rotary Tool Carving Bit
Old 08-15-2024, 07:26 AM
I’ll check them out Shaun. Thanks
Old 08-15-2024, 07:36 AM
Bob Kontak's Avatar
I'll buy from you what you paid for it and split shipping. I'll even pay shipping. Get the Dremel cut off wheels as well with the arbor/mandrell.
I have a hefty Dremel but not the pencil grinder.
I'll bet you keep them. :-)
https://www.homedepot.com/b/Tools-Power-Tool-Accessories-Rotary-Tool-Accessories/Dremel/Cutting/N-5yc1vZc25mZgrZ1z0sqfy
1981 911SC Targa
Old 08-15-2024, 07:42 AM
Critical piece of info on the pneumatic pen. Any tool with a wide head: cut-off wheel, flap sander, wire brush (Harbor Freight has an awesome package of brushes), you have to cut the shaft down so only 1/4" max shaft is showing after inserted in the pen. At 56K RPM, the heads which aren't perfectly balanced makes the shaft bend over like wind on a blade of grass.
For straight shafts like burrs and diamond bits, you don't need to cut them down.
It is an extremely useful tool. I use mine for so much from polishing the insides of Allen bolts for plating to cutting and grinding and shaping everything else.
Old 08-15-2024, 07:48 AM
fastfredracing's Avatar
Darn you guys and your fancy tools. I must have one of those now
No left turn un stoned
Old 08-15-2024, 10:45 AM
As far as getting into tight spots, I bought this flex shaft attachment for my Dremel about 5 years ago and it's paid for itself a million times over.
Great for metal rehab and cleaning up carb and brake components!
Dremel Flex Shaft Rotary Tool Attachment with Comfort Grip and 36” Long Cable
Old 08-15-2024, 10:54 AM
What?
Eric Hahl's Avatar
Multi tool?
________________________________________
Eric Hahl
85 911 to 73RS backdate, a.k.a. "Gretchen" (SOLD)
2015 981 Cayman S (Sold)
23 Outback Wilderness & 23 BMW R1250GS
Old 08-15-2024, 10:57 AM
HobieMarty's Avatar
Originally Posted by Shaun @ Tru6 View Post
That's pretty cool. I was thinking a cordless Dremel with a cut off wheel.
Wonka
Old 08-15-2024, 11:06 AM
